The Official 2014 audio upgrade thread
Old Sep 1, 2015 | 07:15 PM
  #1921
CVORoadKing2013's Avatar
CVORoadKing2013
Originally Posted by hikervt
CVORoadKing2013, thanks a lot for all your input. I am headed to the dealer on Friday and will most def insist on watching what they do. Can you tell me what your full setup is? Front speakers only? Amp? Stage II speakers?
Stage II speakers and amp fairing only
Just like you only I am a road glide special
Old Sep 1, 2015 | 07:23 PM
  #1922
hikervt's Avatar
hikervt
Perfect, I will shoot for your settings. One last thing, does your radio play sound when the switch is in the accessory position? Maybe you already answered this, sorry if it's a repeat.
Old Sep 1, 2015 | 07:25 PM
  #1923
CVORoadKing2013
Can't say I have tried. I will check in the morning and let you know
Old Sep 2, 2015 | 06:58 AM
  #1924
hikervt's Avatar
hikervt
Hikervt
Just went threw this and had some of the same issues as you
Sounds like you got the wrong download like I did .
I originally had 192_off.bin
This came out to the dealer downloading speakers only no amp
You want. Stage2/ tier2 /upper fairing
If everything is done right it should be 208_0ff.bin
Once this was done my system sounded much better and it can be heard at speed( or at least I can in my rgs with a 14" windvest )
Prior to the right download I was ready to pull the system and get a refund
CVORoadKing2013,
When you check your radio this morning to see if you have sound in the Accessory position, can you also check to see if you are getting 208_0ff.bin when the bike is off and when it's running? Reading last night it appears the bin file can be different when the bike is on vs off. At least that is what I thought I read.
Thanks
Old Sep 2, 2015 | 09:17 AM
  #1925
CVORoadKing2013
CVORoadKing2013,
Thanks
In the Accessory position my radio works
Not sure how to check the .bin file when the bike is running. So if you have a procedure to check please let me know.
Old Sep 2, 2015 | 09:50 AM
  #1926
FLYINGBROKE's Avatar
FLYINGBROKE
same as when its off just when you have mute button held and switch in run position go ahead and hit start right away
Old Sep 2, 2015 | 03:22 PM
  #1927
CVORoadKing2013
CVORoadKing2013,
Thanks
Bike running I have 208_on.bin
Old Sep 2, 2015 | 03:26 PM
  #1928
hikervt's Avatar
hikervt
That's good to hear you do have sound in the accessory position. I was hoping that was your answer. As for checking the .bin with the bike running you sort of do it the same way. Hold the mute/power button then start the bike. Don't let go of the button until you hit the accept button on the startup screen. Then release and you should be at the same diag screen.
Thanks
Old Sep 2, 2015 | 03:40 PM
  #1929
hikervt's Avatar
hikervt
Ha, looks like you were replying at the same time I was. Thanks for checking! I am headed to the dealer on friday. Will let you know how it turns out.
Thanks again.
Old Sep 2, 2015 | 07:14 PM
  #1930
hikervt's Avatar
hikervt
So interestingly enough I went to go for a ride this evening... turned the switch on and listen to the radio for a minute and it was very loud at just under half. Then as soon as I started the bike the volume cut to where I almost couldn't hear it. Well I figured it was the AVC so I went into settings and it was on 4.. Cycled it all the way down to off, backed out of the screen then right back into the settings screen, turned the AVC back to 4. Volume was 100% back with the bike running. Sound was amazing! So who knows what the problem really is. Flash? AVC which is probably software? Well at least I know how to get sound back up to where it should be. As for anyone questioning Boom Stage II, I'd have to say it sounds amazing when it's working right.
Now if the dealer can get the sound to work in Accessory mode I might actually be happy!
