The Official 2014 audio upgrade thread
Old Jun 27, 2016 | 08:53 AM
  #2121
DeluxeW00kie's Avatar
DeluxeW00kie
Originally Posted by Bertk
I found that using the BT LOC with 1.19.2 sounded a little better than with the LL, but still not good. The BT LL and 1.19.0 sounds the best to me with a stock flash.
Did some tinkering yesterday. removed the LOC, reinstalled the bt355, using version 1.19.0 (thank you forum resources!!). I'm also reflashed for 0 amps and 4 speakers. I marked the factory location for the gains on the bt355 and turned the volume up 3-4 clicks from max (boom 4.3) and started turning the gains up. I'll be damned, back to factory marks was perfect. Super loud, clear, not much distortion at all actually. I never ride with it that high, but good to know it can do it. Out with the lady last night and I had the music up a little over 1/2 way and it was nice and clear. bass was 3 bars, treble was right in the middle ( I had to turn it down, was a little to "bright" for my liking). I'll ride it around a few more days, but I'm pretty happy with this setup. Only thing I'm turned off by is the lower fairing speakers. They benefit the passenger, but as a rider I hardly notice them : (
Old Jun 28, 2016 | 11:21 AM
  #2122
Bertk's Avatar
Bertk
Good to see it's sounding better. The default marks on the LL are very close to where you want to be. You will want to tune the distortion out. Fade to each pair of speakers to determine where the distortions is coming from and reduce the gain setting on the LL until the distortion is gone. On the stock HU you should be distortion free up to volume 15.
The BT6.5's tend to on the bright side. As far as the lowers fading out, that is the nature of the beast for most speakers in that location.
Old Jun 28, 2016 | 11:53 AM
  #2123
DeluxeW00kie
I agree with all the above. I'm happy with how it sounds now, maybe down the road I'll change the speakers out to hertz or w/e, but I'm pleased with it now. I'll see how my round trip from CT to Montreal and back via Maine goes in 2 weeks. That's lots of miles to listen to music or nothing at all.
(side note: were you on the XLForum before Bert?..I swear your name is familiar to me..)
Old Jun 28, 2016 | 12:27 PM
  #2124
Bertk's Avatar
Bertk
That would be a really to test! Just keep the volume at a distortion free levels. Enjoy your trip.
Nope, not me.
Old Jun 29, 2016 | 01:23 PM
  #2125
redlegend's Avatar
redlegend
3rd Gear
Default front speaker pods
SO do we really need to have the 3 MF bolts for the front speaker pods? As I count it there is 3 on the out side which holds them really well. Then the two in the middle on the sides. Why does there need to be three under the damn radio? I still have my front end apart from installing my amp switch sounds awesome. Am I ok to just leave one bolt in the bottom or should I fight to put the other two in???? Any ideas???
Also is it worth it to put in the poly fill in the pods? Whats is your take on that???
Thanks
Old Jun 29, 2016 | 03:24 PM
  #2126
Bertk's Avatar
Bertk
Thanks
It's not that hard with a 1/4" drive ratchet, long extension(s), swivel and socket.
Old Jun 29, 2016 | 04:04 PM
  #2127
Greatsteaks's Avatar
Greatsteaks
Thanks
Yes, get it back in there, it's structural and you want as little vibration as possible.
Old Jul 4, 2016 | 12:02 PM
  #2128
Springerfan's Avatar
Springerfan
I have found that a flex head ratchet wrench makes the job easier as well.
Old Jul 4, 2016 | 12:06 PM
  #2129
Springerfan
I mounted Hertz HCX 165's in the pods with no issues.
Old Jul 5, 2016 | 06:11 PM
  #2130
neonflx's Avatar
neonflx
On a 2014 SGS do I need to flash the HU back to stock before installing a BT LL? The dealer flashed the unit a while back.
I am running xbr300x2 with Kappa's 62.11i, after installing the BT LL the sound is worse than without it, I did a radio reset as recommended by BT and play with the gain freq still sound is very flat with no bass at all.
