The Official 2014 audio upgrade thread
Old Jun 15, 2016 | 01:51 PM
  #2111
Springerfan's Avatar
Springerfan
Thanks Ultra, one of my main concerns is how I connect the input/output from the head unit and amp? Do I need anything different as far as connectors other than the speaker lid wiring? BTW, I have a service manual but speaker lids are not covered and I have yet to find the connector for the rear speakers.
Old Jun 21, 2016 | 03:42 PM
  #2112
DeluxeW00kie's Avatar
DeluxeW00kie
Hey guys! Long time stalked, figured I'd chime in with some recent updates on my 15 RG.
Earlier in the year I did a BT kit with the 2180 amp and 2 speakers. I added lower fairing and 2 more titan speakers and recently had the bike reflashed for 0 amps, 4 speakers and removed the LL.
When I had installed the fairing speakers I had taken the pods out and sealed the halves together. I recently added some poly fill to the pods and the lower fairing pods as well. I picked up a roll of speaker tape and used that to seal the lower speakers into the pods also. I won't win any competitions with this setup, but damn if it doesn't sound good.
My next project will be to add speaker lids and some 6x9's and change the amp to the bigger BT offering. Here's my one question. Would it be worth changing out the titan speakers up front to hertz or would the difference even be noticeable?
Rant over, back to riding!
Old Jun 21, 2016 | 05:20 PM
  #2113
Greatsteaks's Avatar
Greatsteaks
Why did you remove the line levelers?
Old Jun 21, 2016 | 11:08 PM
  #2114
DeluxeW00kie
i was advised that running a line out converter and the "0 amp , 4 spkr" flash would be the best way to get clean sound out of my setup. figured id give it a shot. Downside, without the LL, theres no way to adjust anything on the BT amp like you would on an ARC or Diamond.
Old Jun 25, 2016 | 04:12 PM
  #2115
fallenhillbilly's Avatar
fallenhillbilly
Well which do you think sounds better 0 amps 4 speakers with the line leveler or 0 amps 4 speakers with a line out converter.
Thanks
Old Jun 25, 2016 | 08:31 PM
  #2116
DeluxeW00kie
Thanks
Good question! i just went back to 1.19.0 from 1.19.2 today. I'll take out the LOC and swap my bt355 back in. I'll report back with details.
Old Jun 26, 2016 | 10:39 AM
  #2117
Bertk's Avatar
Bertk
Thanks
I found that using the BT LOC with 1.19.2 sounded a little better than with the LL, but still not good. The BT LL and 1.19.0 sounds the best to me with a stock flash.
Old Jun 26, 2016 | 10:08 PM
  #2118
redlegend's Avatar
redlegend
3rd Gear
Default finishing amp install
So I need some help. Finishing the amp install on my 2015 ultra glide. I installed a 300 watt kicker 4 channel amp. I ran all my inputs to the factory audio, and ran new wiring to the output of the amp. My question is where do I run my remote wire??? Much help is appreciated.
I am using kicker C5's all the way around.
Old Jun 27, 2016 | 12:09 AM
  #2119
Bertk's Avatar
Bertk
You can run it off the cigarette lighter. The purple wire is hot.
Here's the way I wired it.
Old Jun 27, 2016 | 08:23 AM
  #2120
redlegend's Avatar
redlegend
3rd Gear
Ooh thanks for the info. I'll finish that up this afternoon after work.
