soundstream install ,which power connector
Old Oct 19, 2013 | 02:08 PM
thelawnmowerman's Avatar
thelawnmowerman
Default soundstream install ,which power connector
Not visited this section for a while, but after some advice from Ultra last time I did, I got a Sound stream 520 amp, and I've finally got round to ordering the Polks to go with it. They are to be fitted in my Dead centre fairing, question is what quick release power connector do I get for this ..
Old Oct 19, 2013 | 03:06 PM
Pioneer74's Avatar
Pioneer74
Are you looking for an installation kit? Any 8 or 10 gage auto kit should work.
Old Oct 19, 2013 | 04:30 PM
thelawnmowerman
No , I've got the wire, but my fairing is quick release, so I want a quick release power connector.
Old Oct 19, 2013 | 04:57 PM
Pioneer74's Avatar
Pioneer74
How about this:
Amazon.com: CES 10 Gauge 2 Pin Quick Disconnect Harness: Car Electronics Amazon.com: CES 10 Gauge 2 Pin Quick Disconnect Harness: Car Electronics
Old Oct 19, 2013 | 11:47 PM
thelawnmowerman
Thanks , that looks like it will do the job perfect ..
Old Oct 20, 2013 | 09:59 AM
wils5150's Avatar
wils5150
I use that one in the amazon link works like a charm,
Old Oct 20, 2013 | 12:20 PM
speedracerx0509's Avatar
speedracerx0509
I have the same amp. Is there quick disconnects similar to a deutsch connector that will work with an 8ga wire. I have not seen any that will accomodate 8ga. Would like it water proof as the connector will be between saddlebag and rear fender.
Old Oct 20, 2013 | 02:01 PM
Pioneer74's Avatar
Pioneer74
This should be pretty water tight when connected. Put a plastic bag around it and tape it when disconnected. Haven't scoured the internet, but probably expensive and hard to find what you are looking for.
http://www.walcottcb.com/tp8-gauge-p...nect-p-82.html
Old Oct 21, 2013 | 07:14 PM
speedracerx0509
This might be better.
http://www.walcottcb.com/tp8b-fused-...wire-p-75.html
This way I won't need to cut the 8ga wire i'm using now, just start fresh, 8ga with fuses and disconnects. hmmmmm?
Old Oct 22, 2013 | 04:33 AM
Pioneer74's Avatar
Pioneer74
Nice find, but man is that expensive. Will definitely work.
