CB Install in FLHTC
Old Oct 25, 2013 | 07:30 AM
Larry Davis's Avatar
Larry Davis
Default CB Install in FLHTC
Any Harley electrical/audio techs on here? I can buy on Ebay new/old stock cb module that is HD part # 76236-06a for $199. Ad says fits 06 and later FLHT, but check with dealer to insure fit. The new part number buying direct from Harley is 76416-06c for $299. When comparing the pictures each unit looks exactly the same except the newer part number shows a small extension from the casing with a hole for mounting to the existing radio. Would like to save that hundred bucks if the older part will work and can be properly mounted. Either my dealer doesn't know for sure or they just want to sell me the newer part number. Does anyone on here know the answer????
Old Oct 25, 2013 | 07:37 AM
UltraNutZ's Avatar
UltraNutZ
Larry.. PM Streetglidewalt. I think he still has his CB module that was removed from his 12 FLHTK. The older part number you listed above will work perfectly fine for you as well. It's just a superceeded part #
roadcapt
Apr 18, 2025 08:39 PM
Stephen D
Audio Systems
Feb 26, 2014 07:54 PM
IBHarley
Dec 11, 2012 12:38 AM
Fred Garvin
Audio Systems
Apr 23, 2012 06:42 AM
jimmydsmith7
Oct 11, 2011 07:13 PM
