Adding older CB module to a 2019 RGS
Old Dec 23, 2018 | 02:12 PM
roadcapt's Avatar
roadcapt
Default Adding older CB module to a 2019 RGS
My question is will the older CBs with part number 76236-06C work with bikes that have the infotainment radio?
The new part number on the Harley website is 76000188. I see quite a few used ones that I am interested in and can not tell they will work or not, or if the cabling is different. Anyone add an older CB to their bike?
I have a 2019 Road Glide Special that I would like to add a CB to for our HOG chapter rides.
Thanks.....
Old Dec 23, 2018 | 04:15 PM
groupw's Avatar
groupw
........ i can't imagine a CB module for the Harmon Kardon unit being interchangeable w/the Boom system.
Old Dec 23, 2018 | 04:26 PM
MilesOfTexas's Avatar
MilesOfTexas
Thanks.....
No sir, will not work at all.
Old Dec 23, 2018 | 06:36 PM
Toypuller's Avatar
Toypuller
Neither will a Sirius/XM module.
They don’t carry over from 18 to 19.
Just an FYI
Old Dec 26, 2018 | 02:45 PM
FurryOne's Avatar
FurryOne
Thanks.....
Actually, the #76000188 is an old model, replaced by the #76000486A, which says that it fits 2014-2019 models. Also, Harley doesn't sell a CB antenna that fits bikes with the newer cast rear frame members. For a decent antenna I used a 3' Firestik2 kit. I had to drill one hole in the cast frame to mount it, but the antenna went through the hole reserved for it. You can read my write-up on it at the website below.
Old Dec 26, 2018 | 04:07 PM
prostar's Avatar
prostar
Boom System Is made by Harmon Kardon I thought?
Old Dec 26, 2018 | 07:43 PM
FurryOne's Avatar
FurryOne
Just an FYI
I wouldn't be so sure about that. The only thing different between the '14-'18 Sirius/XM unit and the '19 unit looks to be the different bracket included for the antenna. Also, the CB module (#76000486A) fits '14-'19 GT & GTS models, and so does the extra Audio input harness for the 7-pin DiN plug (#69200865), and the harness for the 3.5mm AUX input (#69200907).
The fact that both the GT & GTS systems are made by Harman International would point to them not obsolescing all the peripherals that still work fine.
Old Apr 18, 2025 | 08:39 PM
D Dot's Avatar
D Dot
I know it it an old thread but why wouldn't it work. I have both in front of me and the have the same Midland model number on them. just different connector. It seems to me that a cb is a cb and you change the power connector and it should work?
jeremyjp
Audio Systems
Mar 2, 2020 09:09 AM
Circa58
Jun 9, 2019 06:46 AM
santajim
Oct 21, 2018 08:19 AM
patrick74
2014-2024 Touring Models
May 12, 2014 07:36 PM
hwy17v
Nov 3, 2013 08:55 AM
