Series or Parallel - Bridged or not Bridged
Old Apr 9, 2014 | 06:20 AM
ChrisHall11's Avatar
ChrisHall11
Default Series or Parallel - Bridged or not Bridged
I have a:
2014 SGS
Biketrinics BT4180
Focal 165 KRC's 6 1/2" (4 ohlm) Front
Polk MM571's 5" x 7" (2 ohlm) Rear
My question is do I install speakers in Series or Parallel. Or separate wires to front and back going to same 2 channel outputs on Amp? Do I Bridge the Amp to 2 channels or leave it alone at 4 channels?
The reason why I ask is that some days I will ride with saddle bag rears and other days I will want to remove the saddle bags. So I don't loose power when I disconnect rears, I figured it might be a good idea to bridge Amp to 2 channel and install 4 speakers of them, then when I ride saddles less, all the power will then go to my fronts.
Thanks for any advice,
Chris
Old Apr 9, 2014 | 08:20 AM
Pioneer74's Avatar
Pioneer74
Leave it 4 channel. Wire each speaker separately.
I'm not even sure you can bridge that amp, but even if you could, I can't imagine a way to do it with all 4 and make it right. If you could bridge it you would have to run them in series because parallel would drop it to 1 ohm.
Old Apr 9, 2014 | 09:01 AM
ChrisHall11
Unfortunately, my rear speakers are only 2 ohms and the Amp is not bridgeable.
But if rears were 4 ohms and if the Amp was bridgeable, by the looks of this image, with the rears installed Amp would have seen 2 ohms, and with them not installed I believe Amp would have seen 4 ohms.
No loss of power would have happened with either setup. Seems like it would have been a good idea. No?
But I guess the current put out would have been the same, and in the end no louder when hooked to only fronts.
Or if bridge, wouldn't...
2 front speakers alone each have seen 360 Watts at 4 ohms
4 speakers have each seen 180 watts at 2 ohms each
Ohms law is so confusing.
Attached Thumbnails Series or Parallel - Bridged or not Bridged-parallel_wiring.jpg
Old Apr 9, 2014 | 09:18 AM
Pioneer74's Avatar
Pioneer74
4 speakers would have been a 2 ohm load in parallel if all speakers were 4 ohm.
You should have plenty of sound coming from the front speakers with 180 RMS watts out to them. I don't think you will be disappointed. Not to mention the fact that putting 360 watts to each speaker would probably not last very long without damage.
I also have to ask why you would be riding around without saddlebags, or switching then out. The 5x7 is a lid speaker and you won't lose much interior room in the bag so I can't see the need to switch saddlebags out.
Old Apr 9, 2014 | 09:40 AM
ChrisHall11
At times I will be riding the bike with out saddle bags. Just for ***** and giggles. I will be installing a quick connect and grommet where speaker wires go to bags.
Cheers,
Chris
Old Apr 10, 2014 | 04:20 AM
ridedaddy's Avatar
ridedaddy
Hmmmm..... A bagger with no bags....... Enough said!!
Old Apr 10, 2014 | 06:17 AM
Gannicus's Avatar
Gannicus
Not to mention the aesthetics . . . Can't say I've seen that in all my years of riding across the states. . . .Guys buy baggers for a reason. . .lol
Old Apr 10, 2014 | 07:05 AM
UltraNutZ's Avatar
UltraNutZ
+1
Delgado130
Audio Systems
Mar 11, 2019 07:46 PM
Jagpanzer
Audio Systems
Oct 11, 2014 08:30 AM
Moxy
Audio Systems
Oct 21, 2013 12:44 PM
Eshaw301
Audio Systems
15
Jun 14, 2013 11:56 AM
viperr817
Jun 9, 2011 11:11 AM
