amp question
Old May 4, 2014 | 03:25 PM
roadkingdoc's Avatar
roadkingdoc
Default amp question
i have a 14 ultra. i have upgraded to boom speakers front and rear. i do a lot of one up riding with the tour pack off. i would like to add a two channel amp to the front speakers and run the rear speaker off the stock head unit when riding two up. is there a problem with this type of setup? i am a novice audio guy obviously. thanks for any comments.
Old May 4, 2014 | 04:03 PM
GLACIERPEARL's Avatar
GLACIERPEARL
No problem,...however, the Ka-Boom speakers won't take too much power , before failing.
Old May 4, 2014 | 05:01 PM
JMJOHN's Avatar
JMJOHN
Sponsor
roadkingdoc ,,,,,,
this amp kit will do exactly what you want, http://www.jmcorp.com/ProductDetail....=JMAA-1800HC14 and won't be quite so hard on the KaBoom speakers as the J&M ROKKER series ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old May 4, 2014 | 05:53 PM
GLACIERPEARL
You could put a Rockford PBR 300/2 in there, and just keep the gains set low. Only run you about a buck-fifty...
Hogtunes 2 channel amp is around $300..... way too much...
If the Alpine KTP-445A was 2 ohm stable, that would be the ticket, but.........
Old May 4, 2014 | 08:27 PM
roadkingdoc
what is a better speaker i could go to?
Old May 4, 2014 | 09:09 PM
Ratrod49's Avatar
Ratrod49
You could try the Clarion XC1410. Its similar to the KTP-445A, but it says it is 2 ohm stable. For speakers the Infinity 62.11i are awesome.
jread2
Audio Systems
Nov 13, 2018 09:45 AM
Cozz
Audio Systems
18
Dec 27, 2015 07:03 PM
Riveroger
Audio Systems
Dec 22, 2014 12:25 PM
SFDonovan
Audio Systems
Jun 11, 2014 07:27 AM
Warden
Electrical/Lighting/Alarm
Jan 17, 2009 11:31 AM
