Radio conversion from 2006 to 1993
Old May 13, 2014 | 01:44 PM
intensecombat's Avatar
intensecombat
Default Radio conversion from 2006 to 1993
I have a 1993 Classic Ultra. My Radio burned out an I now have a 2006 Harmone Kardone to put back in. I also have the 23 pin and 35 pin harness connectors to go with it. I had to wire the connectors (mostly the 23 pin), ( just the rear speaker connections on the 35). No back seat controls. I cannot seem to get it to turn on. I checked it in another bike and it works. Can anyone give me some ideas?
Old May 14, 2014 | 05:23 AM
UltraNutZ's Avatar
UltraNutZ
I will look in a few when I get to work but as memory serves me, there are 2 battery, 1 ignition, and 2 ground wires in that 23 pin connector. They all need to be wired for the unit to power on.
Old May 14, 2014 | 07:42 AM
intensecombat
Thanks UltraNutz. If you can, will you let me know which pin the ignition lead goes into. The power and ground leads are where they should be.
Old May 14, 2014 | 07:47 AM
UltraNutZ's Avatar
UltraNutZ
Pins 10 and 20 are battery +
Pins 11 and 19 are ground
Pin 12 is accessory enable (which in non HD terms means accessory switched power)
Old May 14, 2014 | 07:40 PM
intensecombat
It was the pin 12 that I didn't have. Will try it first thing in the morning. Thank you
Old May 16, 2014 | 02:23 PM
intensecombat
UltraNutz, that did the trick. Thank you.
Old May 16, 2014 | 02:32 PM
UltraNutZ's Avatar
UltraNutZ
glad you got it bud....
Old May 17, 2014 | 12:22 PM
intensecombat
Default One more question
I am having trouble with the right handlebar controls for the radio. All switches have been tested and are OK. I need to know what pins they connect to. The matrix diagram does seem to match. Are all three switches connected to the one C4 pin? Where does the common go? I have tried it numerous ways that don't work completely or all do the same thing.
I am getting a head ache trying different combo's and staring at the schematics.
Please help
Old May 17, 2014 | 10:32 PM
intensecombat
I have found my problem. Common went to C4 and up, down, and band went to R0 thru R2 respectively. It works!
Old Aug 28, 2015 | 03:38 PM
joebedford's Avatar
joebedford
Did you make a diagram that maps the new connectors to the old?
The radio in my '96 is dead and I'd like to update.
Did you have to do anything to the physical mount to get the new one in?
Ron C
Electrical/Lighting/Alarm
May 12, 2015 09:39 PM
intensecombat
May 14, 2014 05:31 AM
nmusti
May 3, 2013 08:49 AM
xk49
Nov 4, 2012 07:09 AM
RidemyEVO
May 30, 2010 10:53 PM
