Grounding a Biketronics BT2180
Old Jul 5, 2014 | 09:00 AM
Street_Glyding's Avatar
Street_Glyding
Default Grounding a Biketronics BT2180
My BT2180 amp and 7.1" Pro Line speakers should be here on Monday. The bike is stripped down and ready for the install.
In anticipation, I was reading over the instructions. They state to ground to the triple tree. However I've always read that the best grounding point on a bike is directly to the batter (or additional fuse block that I have installed).
What do you guys think is the best way to ground it?
Old Jul 5, 2014 | 09:10 AM
1HD2NV's Avatar
1HD2NV
Since running power wire anyway I ran ground to battery as well when I installed my 2180 last week.
Old Jul 5, 2014 | 09:19 AM
Street_Glyding
Looking at the pictures, the wire doesn't look long enough. What gauge wire did you use?
Old Jul 5, 2014 | 09:45 PM
P'cola Hog's Avatar
P'cola Hog
I grounded mine to the triple tree, works great. However I did ask them to send another piece of 10ga wire in case I decided to ground to battery. When talking with BT they said try grounding to TT first because it'd helped with clarity.
Remove HU and you'll see and have great access to TT factory ground....top R. side, facing bike.
Old Jul 6, 2014 | 06:30 AM
UltraNutZ's Avatar
UltraNutZ
to the battery
use the same ga wire as used for the battery + wire.
Old Jul 6, 2014 | 07:45 PM
1HD2NV's Avatar
1HD2NV
BT uses 14AWG for both power & ground. I picked up a 6' piece at my local car audio shop & cut to fit.
Baja38ss
Audio Systems
Feb 22, 2016 01:54 PM
jayhawkclint
Audio Systems
May 27, 2014 03:14 PM
benson1603
Jul 11, 2013 01:12 PM
NJShoreScott
Audio Systems
Mar 28, 2013 01:40 PM
flhxmc
Audio Systems
Dec 12, 2012 03:43 PM
