Amp ground location question?
Old Feb 21, 2016 | 10:14 AM
Baja38ss's Avatar
Baja38ss
Default Amp ground location question?
Getting ready to install a b2 amp in my 08 Sg. I did search this but didn't find my answer.
I know majority run both positive and ground to battery terminals. I'm curious why run ground to battery? I've read a couple of amp install directions and most state not to extend ground any further than what's supplied. Also noticed that most ground wires are considerably shorter in the amp wiring kits you buy. Witch also state not to extend ground wire. Just looking for some insight on this from the knowledgeable ones. Appreciate the help.
Old Feb 21, 2016 | 10:18 AM
Cobra1's Avatar
Cobra1
Where else would you put the ground wire? The frame? Bad choice as it is steel and not a good conductor for a high current amp. I don't understand the instruction saying not to extend other than they are concerned on the splice and wire size of extension.
Old Feb 21, 2016 | 10:34 AM
MikeTD3's Avatar
MikeTD3
Huh? Isn't everything else including the battery grounded to the steel frame?
Old Feb 21, 2016 | 10:46 AM
haze324's Avatar
haze324
From another post. Read Fosgates amp install guide it specifically recommends the battery on motorcycle installs.
"It's a resistance issue... resistance = total area of the circuit or wire... with a wire, you can calculate resistance as length X diameter. So, a shorter wire will have less resistance. The basis of the short ground wire is from the early days of car audio where a high powered amp was pushing 200W. The typical power wire was 8ga. Compard to 15ft of 8ga wire the chassis of the car (whaich was quite substantial in the 80s) is of low resistance. Look at where we are today. A modest system has over 1000W and the primary power wire is at least 4ga if not 0ga. At the same time the metal of the car itself has gotten thinner and as such a worse conductor. Length doesn't matter. Resistance does. As long as the ground is of low resistance, there won't be an issue. The same goes for the power wire. If you are looking at using 0ga for the power wire, you will proably get a better ground by going straight back to the battery with the same size cable."
Old Feb 21, 2016 | 11:15 AM
floridapoolboy's Avatar
floridapoolboy
My amp install kit had a short ground wire, but way too much power wire. I simply cut the power wire to length for both power and ground, ran both back to the battery, and marked each end of the ground with a sharpie. No law says you can't use the power wire for ground also!
Old Feb 21, 2016 | 11:30 AM
Baja38ss's Avatar
Baja38ss
Thanks, haze324..
Knew there had to be a reason, majority of installs were running both to battery terminals. I just couldn't find the answer. Also after reading your post most of the pdf's I read are geared towards the auto market and not bikes like stated.
Old Feb 21, 2016 | 11:32 AM
Baja38ss's Avatar
Baja38ss
floridapoolboy funny you just mentioned that. Was just thinking same thing
Old Feb 22, 2016 | 10:28 AM
AAWAV's Avatar
AAWAV
just use left over Plus cable for ground (I heat shrink wrapped the ends with black of it so you cannot make a mistake )
Old Feb 22, 2016 | 01:54 PM
jmaniace's Avatar
jmaniace
Go to the auto parts store and get black wire. I ran it to the grounding post between the seat and tank instead of to the battery. It's been like that for over a year and have had no problems. Positive right to the battery with a fuse.
Maybe not the right way but it has worked.
Biggzed
Audio Systems
13
Feb 20, 2018 07:24 AM
Weeboy1
Audio Systems
Apr 16, 2016 04:18 PM
JAKE 2544
Audio Systems
Apr 21, 2015 11:14 AM
DeneFXDWG
Audio Systems
Apr 15, 2014 11:02 AM
flhxmc
Audio Systems
Dec 12, 2012 03:43 PM
