I'm going to be putting the Sony MEX-M70BT and want to use the PAC SWI-RC Steering Wheel Control Adapter. anybody use this set up and have anything to say about it?
there are guys out here that run the PAC.
I run the ASWC-1 with the Metra 99-9600 connector (part of the metra kit mentioned).
there is a sticky in the audio forum at the top, providing install and programming guides.
believe price wise the are the same if not, the ASWC-1 will be cheaper (complete total should not exceed 75-80 bucks).
ASWC-1 has mute option (programming) - I love it. not sure if PAC does support the mute option.
Im only going with the pac because if i get it through crutchfield with the head unit it's only 35 bucks. as far as i can tell both units are about the same. It will probably take me a while to get it programmed right since I have never installed one before
