ASWC-1 / Metra install AND PROGRAMMING (left push as MUTE) Guide
Old Apr 15, 2018 | 08:01 AM
  #121
Bobber Jake's Avatar
Bobber Jake
double post
Old Apr 15, 2018 | 08:16 AM
  #122
Bobber Jake
So after driving myself crazy searching for the answer I will just ask. I have the old ASWC on my bike. It is hard wired in. I am replacing it with the new one as the old one was cutting out last year (I will be re grounding the p/w after reading this thread). Can I use the existing wiring that was wired in according to the above schematic, I dont want to have to figure out all this wiring to reconnect it so I can use the metra plug.
Thanks
Old Apr 15, 2018 | 08:31 AM
  #123
SBates08's Avatar
SBates08
Thanks
Bobber what ASWC are you currently using? Metra? And how exactly was it cutting out?
Old Apr 15, 2018 | 08:48 AM
  #124
Bobber Jake
Yes I am using the metra. I had it in my old bike and it worked great. When that bike was totaled out I put it on my new bike. It will work when I first turn the bike on but then it will stop working, then it work intermittently while riding but it is such a pita that I stopped trying to use my thumb controls. But my p/w wire is just on one of the fairing mount bolts (road glide) so I think that might be my problem but bought the new metra already so going to use it.
Old Apr 15, 2018 | 09:05 AM
  #125
SBates08's Avatar
SBates08
The new Metra harness doesn't require the p/w wire to be cut and grounded. Have had some issues lately programming the new Metra. Try moving your current p/w wire to the ground on your amp if you're running one.
Old Apr 15, 2018 | 10:15 AM
  #126
Bobber Jake
I will use the amp ground. However does that mean I cannot just plug the new ASWC-1 into the old plug?
And if not, does anyone have a wiring diagram for hard wiring the new one in. Really wish I would have never cut the wiring!!!
Old May 19, 2018 | 10:00 AM
  #127
Mklitzke's Avatar
Mklitzke
Stage II
Ok I'm new here looking for some help. Need to replace my factory radio. I have the meta wiring harness, the handle bar controller. On my factory radio it has two plugs on the back a 23pin and a bigger one. My kit came with a connector for the 23 pin but I can't find anything for the other connector. Would seem weird to just leave on connector that size unplugged. What am I missing?
Thanks
Old May 19, 2018 | 12:59 PM
  #128
SBates08's Avatar
SBates08
Thanks
You're not missing anything. You'll only use the plug that comes with the kit.
Old May 19, 2018 | 07:01 PM
  #129
Mklitzke's Avatar
Mklitzke
Stage II
Then what is the other plug for?
ShadowforNow
Nov 9, 2018 06:22 PM
G9803
Oct 29, 2014 06:25 PM
jamess71
Audio Systems
Jun 21, 2014 01:12 PM
bummer769
11
Jan 31, 2012 11:25 AM
Abnmarine
Feb 19, 2007 06:36 PM
