Parallel or series?
Old Aug 26, 2014 | 08:16 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Gnarl78
Question, I've heard the 4 ohm BT speakers like power, but if run in parallel do they still need the same power as in series to sound good?
doesn't really matter how you wire them whether series or parallel, they still want power. IMO no less than 100w per speaker would be optimal for these speakers.
Old Aug 26, 2014 | 08:20 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Braveheart1222
Pioneer- My bad, thanks...
Nutz- your correct....
Pearl- silly or NOT... was the reason I asked the question... but thx for your .02
Guys this is the correct amp: http://poweracoustik.com/store/produ...ca4-1600d.html
I heard this amp paired the focals... and my gawrd.. This little fellow does well... IMO way better than SS amps...Which I had as well...
ok one more time because I think I misread and before I throw in my .02 on this.
4 pair of speakers or 5 pair of speakers?
from one description I get 4 pair, from another I get 5 pair
2 pair of titan IIs in the fairing 6.5 and 7.1 correct?
kappas in the lowers
7.1 in the rear pods
6x9s in the lids
if I'm reading that correctly, it's 5 pair of speakers
Old Aug 26, 2014 | 08:25 AM
Braveheart1222's Avatar
Braveheart1222
6x9s in the lids
lol... your .02 is welcomed... as well as the others....
1 pair of titan IIs in the fairing 6.5 (facing the handlebars-inner) and 7.1 stock location
alpine tweeters
6x9s in the lids
All are 4 ohms and I'd like to wire to this amp... CA4-1600D.... If not enough power I'm will to get another amp....
Old Aug 26, 2014 | 08:28 AM
Pioneer74's Avatar
Pioneer74
No worries. We're all here to help.
Old Aug 26, 2014 | 08:38 AM
UltraNutZ's Avatar
UltraNutZ
alpine tweeters
6x9s in the lids
ok, so your front speakers are going to be the ones that give you fits because with that particular configuration of 3 (4ohm) speakers per side you're either going to wind up in parallel at 1.3ohm which will drive that amp into protection mode or you're going to wind up wiring in a parallel/series configuration which will then put your ohm load at 6. Neither of these configurations are going to be ideal or work well.
the rears are easy. simply wire both pair in parallel and to the rear outputs of the amp.
Old Aug 26, 2014 | 08:44 AM
Braveheart1222
in Short... another Amp...sigh.... thanks... Back to the Drawing board...
Old Aug 26, 2014 | 08:51 AM
UltraNutZ's Avatar
UltraNutZ
yeah I'd highly recommend that. another thing worth mentioning. I've never run a series+parallel configuration where speaker phase issues didn't rear their ugly head.
Just not a good idea.
Old Aug 26, 2014 | 08:53 AM
UltraNutZ's Avatar
UltraNutZ
here's my thoughts on this setup.
get a 2 channel amp to run your lids only with plenty of power
use the amp you have to run the lowers and the rear pods in parallel to create a 2 ohm load on the rear amp outputs
run your fairing speakers in parallel on the front channel of the amp
Old Aug 26, 2014 | 09:09 AM
Braveheart1222
Got it... Thank you.. I will give that a try...
Old Aug 26, 2014 | 09:25 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Spec wise, if at all accurate, would put 100 watts to each speaker. Another one of those '1600watt amps' , that's hopefully gonna put out 800....best of luck !!!
Hope you get what your looking for !
