Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Where to run Oil Feed/Return on Turbo Setup
Old Sep 24, 2010 | 05:07 PM
Syclone354's Avatar
Syclone354
Default Where to run Oil Feed/Return on Turbo Setup
Just as the title says. For you guys with turbos, where does the oil feed and return for the turbo come from?
I figure at least one of these can come from the fittings on the oil filter boss on the motor (i have an 07 96B and there are two ports already drilled tapped and pipe-plugged).
Thanks
Old Sep 24, 2010 | 10:29 PM
Syclone354's Avatar
Syclone354
Well I found the Trask installation manuals and their kit has a T for the feed line that goes in with the oil press light sender (thats the way i usually feed the turbos I have done on cars.
For the return they give you a new cam cover or a fitting you install into the cam cover and drain the oil to there. Makes sense and should be very simple to deal with.
Old Sep 25, 2010 | 12:11 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
Former Sponsor
Just do what Trask does goe into your oil filler hole make adapator for it with some piping at a hard ware store. its not hard. drill tap set.....and pipe. Your dip stick wont read right.
Here are his inst...
Unbolt starter solenoid form left front frame down tube, move away from oil fill hole.
Remove oil fill dipstick from the crankcase and install the 35mm filler adaptor for the
turbo oil drain hose. Tighten adaptor by hand and align opening toward right side of
bike. The dipstick will be retained but needs to be remarked. (See Photo 8) Measure
35mm or 1 3/8 inches down from the full mark and cut a grove in the stick this is now
your full mark. Position the fitting slightly toward the engine to keep the drain hose
away from the exhaust.
I hope this helps.....
Old Sep 26, 2010 | 08:31 AM
Syclone354's Avatar
Syclone354
Thanks for the reply. What model did those instructions come from? My dipstick goes into the oil tank (regular softail setup) so i figure those instructions are for another model (vrod maybe?)
Old Sep 26, 2010 | 09:42 AM
DRAGO'S BIKE WORKS
Former Sponsor
I am sorry I am a dumb a$%$% Where I got Vrod out of this..... You have a softail...... dumb me... LOL LOL Go right into the cam cover up top. If you have a oil cooler tie in to that for supply and return...
Old Sep 26, 2010 | 11:00 PM
Syclone354's Avatar
Syclone354
lol thats cool i kinda figured that was v-rod. yea i am definitely going to run an oil cooler, so i think the oil return will T into the return for the cooler. I just need to figure out which is the feed and which is the return for the cooler...
Old Sep 27, 2010 | 09:37 AM
Syclone354's Avatar
Syclone354
Just curious, do you always put oil coolers on the turbo bikes you do?
Old Sep 27, 2010 | 08:32 PM
DRAGO'S BIKE WORKS
Former Sponsor
Yes if you can
Old Oct 4, 2010 | 12:25 AM
Syclone354's Avatar
Syclone354
Originally Posted by DRAGO'S BIKE WORKS
Yes if you can
Do you like the Harley vertical style cooler or do you use something else?
Ive been searching more and can not find an answer about those ports on the front of the engine by the stock oil filter boss. I would think you could use them to feed a cooler, but no one seems to know.
Old Oct 4, 2010 | 09:24 PM
DRAGO'S BIKE WORKS
Former Sponsor
I like the vertical style one its is clean and out of the way but you may have a problem with your turbo and pipe. I think if you use them it will re direct the oil from your filter I will have to look at the HD book it will show oil flow. You can also buy the oil bracket only with out the filter and use the ports from it.
KarlVan
Milwaukee Eight (M8)
88
Oct 7, 2021 05:17 AM
brian4.2
Oct 20, 2018 08:54 AM
IRON1250
EVO
20
May 8, 2018 02:37 PM
rocketman11
Oil Archive (no new posts)
Sep 13, 2017 11:27 AM
