Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Jis
Old Feb 23, 2022 | 01:42 PM
gregintenn's Avatar
gregintenn
You are correct, sir. I buggered a lot of screws through the years before some kind soul pointed out the error of my ways. I bought a cheap set of JIS screwdrivers off Amazon. They work great.
Old Feb 28, 2022 | 09:45 PM
Max Headflow's Avatar
Max Headflow
Personally I think that 99% of the problems are based on 2 things.
1. You can use a Philips but it has to be the right size. The problem stems from people using the wrong size to start, say a #1 where a #2 fits better.
2. Most screws are into aluminum or some zinc alloy. The screws oxidize in place and stick. Generally a little tap on the screw driver / socket drivers knocks them loose.
Now IIRC this JIS standard happened around the late 60s. The main thing I saw was a standardization of metric thread pitches. I worked mainly has a Honda MC mechanic between 69 and 79. Once I figured out how to get the screws loose, I very really ever had a problem popping a screw loose and if I did it was mainly because the screw and base material were corroded. While I had impacts for stuck screws My main screw driver was a Howa T handle. It was made to pre-JIS specs. More common for me was to break the #2 Snap-on Phillips on stuck screws. I did occasionally use a special ***** punch to remove the really stuck screws.
I guess one of the things to note is that tapping a Philips screw driver into a JIS screw likely made it a Philips screw..
Old Feb 28, 2022 | 10:39 PM
TriGeezer's Avatar
TriGeezer
Any engineer that still specifies Phillips screws of any type should be tarred and feathered.
Old Mar 1, 2022 | 06:55 AM
gregintenn's Avatar
gregintenn
Honda made screws out of old chewing gum I think. They were soft.
Old Mar 1, 2022 | 07:13 AM
eighteight's Avatar
eighteight
As a kid working on Honda singles back in the late `60`s , you weren`t getting the engine side covers off with out a cheap hammer driven impact !
Old Mar 1, 2022 | 07:22 AM
gregintenn's Avatar
gregintenn
I ordered mine from JC Whitney. How’s that for a throwback?
Old Mar 1, 2022 | 08:52 AM
bustert's Avatar
bustert
mr. max makes a fine point
an ole trick i use is to use johnson paste wax on the screws. when it dries, it acts as a mild thread lock but yet, you can take the screws out without a hand impact. it also prevents corrosion. an important step is to make sure the holes are squeaky clean every time.
Old Mar 1, 2022 | 11:10 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Get yourself one of these and your carb screwdriver issues will be solved.
Amazon Amazon
Old Mar 1, 2022 | 11:23 AM
Max Headflow
Full 99% of the screws I got out were with the 2 T handles.. I could feel the tops break loose first then the threads. I never stripped any screws out that weren't already damaged.. If really stuck, tap the end of the T handle with a hammer. The CP was used for lots of screws like engine covers. The sharp pin punch for points cover screws where someone bunged up the head. Had multiple 3/8 socket drive #2 and #3 Phillips. Snap-on guy would come by and replace the worn tips for free. The hammer impact was the least used.
Guythunder
Engine Mechanical Topics
May 19, 2024 12:03 PM
tom j
Exhaust System Topics
May 21, 2012 09:26 AM
07 dyna man
Apr 30, 2011 04:11 PM
hawkdsl
17
Apr 5, 2010 12:33 PM
sawdust
Jun 1, 2007 02:53 PM
