Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Evo trouble
Old Jan 31, 2024 | 07:11 PM
Longboom's Avatar
Longboom
Stage III
Default Evo trouble
I have a 97 electraglide with a stock evo. All of a sudden it is now popping bad on acceleration and deceleration. More on the acceleration. Jets are clean. Any thoughts?
Old Jan 31, 2024 | 08:53 PM
im's Avatar
im
Review gaskets at throttle body.
Review cross over pipe for crack at Y
Old Feb 1, 2024 | 10:08 AM
Longboom's Avatar
Longboom
Stage III
Gasket is good and pipe is good
Old Feb 1, 2024 | 01:56 PM
im's Avatar
im
I will guess that you mean gaskets with an S since there are two.
If gaskets are original factory gaskets then it is kinda hard to see unless it was changed lately. Some people test by spraying a small amount of WD40 into the area while holding a steady idle.
I will also guess that you reviewed the Y pipe really well since the crack is sometimes hard to see since it is located under the right passenger floor board.
Is exhaust all original? with no leaks at head or clamps?
Old Feb 1, 2024 | 05:22 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Is the engine misfiring?
Old Feb 1, 2024 | 07:00 PM
Longboom's Avatar
Longboom
Stage III
My y pipe is right behind the rear cylinder not under the passenger floorboard. And I tested both intake gaskets and they are not leaking.
Old Feb 1, 2024 | 07:20 PM
TexasScooterTrash's Avatar
TexasScooterTrash
It's a 97. It's 2024, break down and treat it to a complete CV-40 cleaning and rebuild.
Old Feb 1, 2024 | 10:31 PM
Yankee Dog's Avatar
Yankee Dog
What do your spark plugs look like? Rich or lean?
If lean suspect intake manifold seals or faulty petcock. Check the vacuum line going from carb to petcock or VOES.
As Dan89FLSTC mentions, any missing? Is the "popping" more like a cough? There is a thing called a lean cough with these evo's from bad intake seals or leaks, then there is a cylinder firing "miss" that can be from a bad ignition cam sensor.
With cam sensor, the problem usually crops up after the bike has ran for awhile say 15-30 minutes then starts acting up.
When you say "jets are clean" which jets are you specifically talking about? How about the emulsion tube? idle transfer ports?
Old Feb 2, 2024 | 08:47 AM
bustert's Avatar
bustert
a carb is a dirty port devise, meaning, there are air jets and passages to boot. these control mixture.
a lot of people will think right off it is a lean pop, but it actually could be from a rich mixture.
i assume it is the exhaust and not back feed through the cab.
right off, i would check float level. when accelerating, the mix will go rich and excess fuel will collect in the exhaust and when conditions are right it will ignite, the same for decel, fuel build up in the exhaust.
the plugs may/may not show, depends upon many things.
inline spark testers will show if the ignition is dropping.
Old Feb 2, 2024 | 08:55 AM
Kabear's Avatar
Kabear
Vacuum leak in VOE's either at the switch or the carb. Maybe the hose has a leak. On some bikes the hose from the carb to the switch is inside a protective sleeve. Make sure you check the hose and not the sleeve.
