Classic All 'historic' bikes.
Buying a Basket Case - Questions
Old Oct 14, 2006 | 07:05 PM
BuckeyeFanInFL's Avatar
BuckeyeFanInFL
Default Buying a Basket Case - Questions
I never bought a basket case and not sure all I need to do. Say I find one, is it a matter of checking the VIN#'s, getting the title noterized and exchanging the money?????
Is there anything else I need to do special since the bike is in buckets??
Old Oct 15, 2006 | 10:25 AM
speighd's Avatar
speighd
Default RE: Buying a Basket Case - Questions
Make sure you have all (or most) of the parts and make sure they are for the same model year.
A late model pan cylendar head on a late model would be a lot of work or would run for only a few miles before dying (oil passesages don't match up);
Just make sure you have the proper amount of play in everything when done & make sure the flywheels are aligned.
And yes check the VIN number(s).
Old Oct 15, 2006 | 01:19 PM
panz4ever's Avatar
panz4ever
Buckeye, I gues I would first ask what kind of a basket. Different year models have some parts that will interchange; others will not. Anything after 1970 needs to have a matching fram and vin number.
Old Oct 15, 2006 | 04:45 PM
Hackd's Avatar
Hackd
ORIGINAL: BuckeyeFanInFL
Just make certain that the VINs match the title...A True 'basketcase' will be a complete bike that has been disassembled. It'll be a bonus if over the years all the parts have been 'bagged and tagged'....You're still probably looking at a bunch of small parts that are missing.
Old Oct 16, 2006 | 09:48 AM
BuckeyeFanInFL
I am looking for a 1976 Ironhead or Shovel. By basketcase, I am meaning that the owner has tore it all down and hopefullly set all the parts aside.
I realize that some smaller parts probably wont be there.
The post was angled more toward a legal transfer of ownership. But, tips on making sure I don't get ripped off are always welcome
Old Oct 16, 2006 | 10:17 AM
Hackd's Avatar
Hackd
ORIGINAL: BuckeyeFanInFL...The post was angled more toward a legal transfer of ownership...
I don't see a problem as long as the bike is sold with a clear title. And the VIN's all match. The Secretary of State in Michigan doesn't physically check vehicles. If it's an 'assembled' vehicle in Michigan, you need to get a form from either the State Police, or local LEO's where they run the VIN's to check for stolen stuff, before you can get it registered. Check with your state to see what they require.
Old Mar 11, 2007 | 03:32 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Check with the DMV to see just what documentation you will need to register the bike when it is ready to go, then make sure you get what is needed.
When you start assembling the bike, check the fit of every part before you bolt it on, including the location of any oil passages.
Also, make sure that heads, pistons and barrels match for both cylinders. It can drive you nuts trying to find out why the bike doesn't seem to run quite right when it is caused by differences in compression or port sizes. A friend of mine once had problems with his generator shovel because one valve had a lifter that was converted to solid.
Old May 7, 2007 | 11:40 PM
ftwflh's Avatar
ftwflh
My first Harley was in a basket(7 boxes to be exact) Like stated be sure you get a clear title that at least matches the engine (some aftermarket frames didnt have numbers).Be ready to spend many hours sorting parts to see what you have.Then be ready for close to a 2 yr process of building,hunting down,refabing parts and many many beers to complete it and then you will have a piece of you that cant be replaced.I messed up and sold mine.A 9ft 8in long 1972 hardtail Sporty.
Old May 8, 2007 | 12:30 AM
Toyman's Avatar
Toyman
I purchased a 82 FXRS that was suppose to be all there. The small & big stuff can cost you plenty of greenbacks & grief. Be ready for the worse case scenario when you buy. There will more than likely much you'll need or wantto replace.
grbrown
EVO
23
Jan 23, 2019 03:24 AM
Redseals
Aug 1, 2011 01:38 PM
fxesuperglide77
Ironhead
16
Sep 11, 2009 09:35 PM
StevenT1967
Oct 18, 2007 06:59 AM
83ironhead
Ironhead
Aug 1, 2006 11:40 AM
