Classic All 'historic' bikes.
better braking for Panhead
Old Aug 29, 2011 | 05:58 PM
lazosb's Avatar
lazosb
6th Gear
Default better braking for Panhead
Hi Guys,
I thought of something on the weekend when standing looking at my 58 Panhead and how bad the front brake is. (Yes I know it was always bad even when new) Well yes you can change your entire front fork assembly and put a disk on it but that would ruin the look of the classic. So it got me thinking that 1 drum is bad but perhaps 2 would be ok. Im not sure if this is correct for a 58 but the drum sits on the right side of the wheel if you’re sitting on the bike and there is a locating bolt in the fork. But I know that some bikes have it on the left. Not sure if the forks are independent or not but what would happen if you changed one fork to have the drum locating hole on the left also. Then you could fit another drum to the left side of the bike. Then you have 2 drums on the bike. I know then you have to make to operate on one lever but that is a simple fix with a centre bracket to pull both cables from one lever.
Has anyone done this before? Im sure if ive thought of it 1000 others would have also.
That could be one option but another might be leave one drum on the bike and somehow convert it to hydraulic set up. There might be some work but then you might have more stoping pressure on the drum increasing its efficiency.
Well that said has anyone ever done such things and did it improve the braking of the front brake?
Bill
Old Jan 29, 2012 | 11:55 AM
TwiZted Biker's Avatar
TwiZted Biker
You couldn't get 2 drums and a wheel in there too wide . Hyd. like the rear just warps and breaks the alum backing plate , I went down that road in the 70's . Get an adapter to change out the drum and put a 10" disk on it and GMA has a nice clean quad caliper setup that works sweet on that . Isn't panhead but you'll live longer with it .
gus58
Shovelhead
Jul 19, 2018 11:24 PM
SoaringAgain
Shovelhead
Mar 29, 2017 09:09 PM
shore
Dec 30, 2011 08:28 AM
besibela
Shovelhead
Aug 9, 2011 06:47 AM
abramsm1a
Panhead
18
Feb 26, 2009 11:43 AM
