Unstable rpm when drivin downhill
Old May 4, 2006 | 09:30 AM
hd1952's Avatar
hd1952
Stage II
Default Unstable rpm when drivin downhill
I have a custom buildt bike with an 88 evo and a 103 cui engine with rev tec top. s&s g carburator. When i drive downhill or on flat road and try to keep a low rpm on the engine it jumps like it`s running on kangoro petrol. I don`t have this problem when i turn the gas handle to cruising speed.
Does anybody have any suggestions?
Kindly
Mr. Hansen
From Norway
http://img67.imageshack.us/img67/5364/9967478728wk.jpg
Old May 6, 2006 | 12:06 AM
pococj's Avatar
pococj
Default RE: Unstable rpm when drivin downhill
What gear(s) are you in and what speed(s) are you going when this happens?
Old May 6, 2006 | 03:11 PM
hd1952's Avatar
hd1952
Stage II
The gearbox is Sputhe 5 gear. It happens when i drive in low rpm on 3-4 or 5 gear and try to keep a low speed about 20-40 km/h.
Old May 6, 2006 | 09:38 PM
pococj's Avatar
pococj
I think you're running too low an engine rpm for the speed you're going. Drop a gear at that low a speed, and see if that cures it. Hard on the main bearings, too.
Old Jun 15, 2006 | 07:06 AM
BIGHUS's Avatar
BIGHUS
Stage III
Id have to agree with poco, sounds like your lugging the tranny! Does it have a tach? Optimal RPM for any gear is between 2800-3300 RPM. 40 km/hr is only 25 mph, you shouldnt be out of 2nd gear at that speed! Dont lug your tranny dude, bad bad things will happen!
RK_2014
Oct 14, 2013 03:47 PM
asahi1234
Dec 18, 2010 09:35 AM
trapper_canada
Jul 1, 2009 12:25 PM
Dancemax
May 7, 2009 08:15 AM
blackbob
Aug 12, 2006 09:52 PM
