Low speed and engine control
Seems like I am downshifting too early and causing the motor to lug too much or not having enough revs
This occurs in rush hour when merging at very low speed or coming to lights
I think it's just getting used to it but any insight would be great - thanks
At very low speeds (less than 20mph?) You dhould be in 2nd gear at the most. I rode a GSXR previous tomgroeing up and riding an HD. I still ride it the same as that.
Listen to the bike and feel it....it will tell you when it wants to be shifted.
Seriously though....few more miles on the new bike and a little more time in the saddle and you'll get it.
Note this is suggested from the manual that nobody reads anyway, and assumes you are on level road, you don't weigh a ton, your passenger and your combined weight don't sag the shocks until the rear fender rubs, and you're not running it through the gears trying to look like a badass. It is a touring bike after all
UPSHIFTING (acceleration)
First to second 15 mph
Second to third 25 mph
Third to fourth 35 mph
Fourth to fifth 45 mph
Fifth to sixth 55 mph
Downshifting (deceleration)
Sixth to fifth 50 mph
Fifth to fourth 40 mph
Fourth to third 30 mph
Third to second 20 mph
Second to first 10 mph
If you're in traffic, and in 1st gear.......... use your clutch once in a while.
Yes trying to get the feel for it and in reviewing the operators manual - did read it by the way - it has similar numbers
So I will pay closer attention to that and use the clutch more
