shifting speeds for 6 speed
Old Oct 12, 2007 | 07:36 AM
tacmedic's Avatar
tacmedic
Default shifting speeds for 6 speed
Hey folks, I was just wondering whatspeeds you shift at with the six speed tranny. Just trying to get an idea where other people shift at.
Thanks
Tac
Old Oct 12, 2007 | 07:52 AM
mchildree's Avatar
mchildree
Default RE: shifting speeds for 6 speed
I generally don't even pay attention to speeds (just go by engine sound) until I hit fifth gear. Then I watch my speedo and don't shift into 6th until I'm above 65mph, usually. It doesn't do much good before then. I ride two-up a lot, and I have to wind the gears out into a little higher rpm range with less speed, as compared to what I do when riding alone. Just listen to your motor.
Old Oct 12, 2007 | 08:02 AM
Windup08's Avatar
Windup08
Haven't got my Ultra yet, so still only have experience with my Dyna, but engine sound as about as good of an indicator as you can get. Also keep in mind, it doesn't hurt, and is actually good for the engine to bump up against the rev-limiter once in awhile. My wife gets a kick out of my on-ramp exceleration once in awhile, especially when there isn't much of a curve in the ramp I'll nail it through the first 3 gears and be at or above interstate speed by the time I hit the end of the ramp....makes merging into Wyoming traffic real easy (you know, 1 car a mile ahead and another 2 miles back)
Old Oct 12, 2007 | 08:19 AM
Doug45601's Avatar
Doug45601
I go into 6th gear around 60 mph and it doesn't lug the engine on a flat slab.. saves gas. Oh I know most will say the 6th gear is like overdrive but it's there and I will use it just as long as I'm not lugging the engine. 5th gear is alright past 60 I'm sure but seems to wind up the engine rpm too much for a quiet ride.
Old Oct 12, 2007 | 08:44 AM
tacmedic's Avatar
tacmedic
Ya I try to listen by engine noise too, but unfortunately between the IED blasts and the shootingon my last tour my hearing is pretty much shot to begin with and after I throw in my earplugs or headphones I can't hear jack anyway. [sm=rant.gif]27 yrs oldand I need hearing aids uhgggg! oh well I know italways b worse. AnywayIt just makes it a struggle to tell the right ranges
Old Oct 12, 2007 | 10:04 AM
Londonbike's Avatar
Londonbike
60 mph gives you about 2100 revs in 6th. Under 2000 revs bike appears to lug
Old Oct 12, 2007 | 10:08 AM
jahays32's Avatar
jahays32
I shift @ 2500 rpms
Old Oct 12, 2007 | 05:26 PM
dabuckman's Avatar
dabuckman
I usually shift by sound and speed. When riding 1-up, this usually means shifting up to 6th at around 65. I'll usually leave it there until I drop down to 60 as I agree with London in that the bike begins to lug as it nears 2000rpm and below.
Old Oct 12, 2007 | 05:28 PM
prc1333's Avatar
prc1333
6th gear around 65-70 mph. [/align]
Old Oct 12, 2007 | 08:46 PM
glens's Avatar
glens
20, 30, 40, 50, 60.
