shifting speeds for 6 speed
Old Oct 14, 2007 | 07:45 PM
BobsClassic's Avatar
BobsClassic
Default RE: shifting speeds for 6 speed
Will use 6th also around 65-70 ,unless on flat like someone else said and maybe at 60
Old Oct 14, 2007 | 08:44 PM
goodbirds's Avatar
goodbirds
First gear: getting started
Second gear: school crossings
Third gear: boulevard speeds, steep climbs at slow speeds
Fourth: Parkway speeds 40-45 mph, and hot acceleration on the on ramps
Fifth: Speeds under 60 and above 45, finish merging into 80 mph traffic
Sixth: Steady speeds above 60 mph, and go like heck at 80+
The key is running at or above 2000 rpm in first, second, third, fourth, and fifth. Sixth should be at or above 2200 IMHO. I love this six speed.[8D]
Old Oct 14, 2007 | 10:00 PM
uweldit's Avatar
uweldit
What!!! I don't use 6th until above 75....
On the highway I keep it in 4th-5th (<70mph) in case I need a burst of speed to avoid cagers.
I must be runnin too hard [sm=badbadbad.gif]
Old Oct 14, 2007 | 10:56 PM
Rambler's Avatar
Rambler
go into 6th between 60 & 65 never had a problem with lugging or whinning noise.
Old Oct 14, 2007 | 11:06 PM
glens's Avatar
glens
It's been reported that with the addition of the IDS the manual shift-points are very reasonable. I was shifting, as I said above at 20, 30, 40, 50, and 60 all along, but with Rush 2" mufflers, K&N airbox, and PC-III, I can venture below those points without too much fanfare.
Old Oct 15, 2007 | 07:12 AM
nidan's Avatar
nidan
With the IDS drive in , I can shift lower , generally not below 2500 rpm though.
Old Oct 15, 2007 | 09:16 AM
chornbe's Avatar
chornbe
ORIGINAL: tacmedic
Hey folks, I was just wondering whatspeeds you shift at with the six speed tranny. Just trying to get an idea where other people shift at.
Thanks
Tac
Well, I can say that I don't go anywhere near that nearly pointless 6th gear unless I'm above 70. Everything else is fully dependent on riding style du jour. I don't mind revving the big twin.
Old Oct 15, 2007 | 09:19 AM
chornbe's Avatar
chornbe
ORIGINAL: jahays32
I shift @ 2500 rpms
You should double that now and then. It won't break, I promise. And it actually gets pretty fun above 3500 RPM.
Old Oct 18, 2007 | 10:31 AM
COWBOY_BC's Avatar
COWBOY_BC
Hi all,
These bike need to be run best when run at least to 3000 rpm before a shift and maybe 3400 when shifting in to 6th. Anything less and it's a wonder why people think these bikes clatter. Also that's when the power starts to come on too!
Old Jul 19, 2008 | 10:05 AM
OAKXTREE's Avatar
OAKXTREE
Shifting is different for me with this 96 inch motor, thirty years of riding and I now watch my tack more than the sound. I shift at around 2700 or higher, I hit 55 in fourth gear before thinking about 5th and at 75 I am going to 6th. BTW I had the fifth gear clatter pretty bad before I started using this method of shifting.
&nbsp\\;
any thoughts?
