Help With My Bobber
Old Jun 20, 2011 | 01:16 PM
JokerRides's Avatar
JokerRides
Default Help With My Bobber
I design bikes .(but do not have much at all mech knowledge.)
I wanted to ask you for your suggestions. I have a 1999 1200 I purchased in good condition and converted to bobber.
New wiring DYNA coil and DYNA S Ignition, Battery, key start , high air flow breather and jets.
Problem is about 50% of the time it starts up great.(hot or cold) the other times it kicks back with a little with puff of smoke out carb, upon second try fires right up.
this can't be good on starter gear.
Any suggestions or comments?
Old Jun 21, 2011 | 04:49 PM
frontiercat's Avatar
frontiercat
Possibly the timing is just slightly off?....
Old Jun 22, 2011 | 06:10 PM
motrhd's Avatar
motrhd
+1 sounds a little too advanced, you might also check the advance mechanism and make sure that everything is free and working properly.
I presume that with the Dyna S that you have a mechanical advance.
Old Jul 5, 2011 | 08:56 AM
Chunk's Avatar
Chunk
Follow the story the plugs tell.
jokenroll
EVO
33
Jun 9, 2015 08:05 AM
JokerRides
Jun 20, 2011 09:12 AM
JokerRides
Engine Mechanical Topics
Jun 8, 2011 11:59 AM
firsthd
Welcome Area Only
14
Apr 26, 2011 12:07 AM
pensrider
Exhaust System Topics
Dec 5, 2006 11:40 PM
