Exhaust Leak Clean Up
Old Aug 28, 2023 | 09:27 PM
cj24's Avatar
cj24
Default Exhaust Leak Clean Up
Had a small exhaust leak at the header that caused some browning on the motor fins. Can anyone tell me the best way to clean that up?
Old Aug 29, 2023 | 07:52 AM
uncle kebo's Avatar
uncle kebo
Did you try S1 engine brite and a tooth brush?
Old Aug 29, 2023 | 02:44 PM
cj24's Avatar
cj24
No I haven't. I'm cautious about using products like that as folks have reported damage to finishes, etc. It appears that it rubs off with effort but getting between the fins is a pain. So, maybe something like S100 is what I need - I want to start with the most mild products first though.
Old Aug 29, 2023 | 02:48 PM
Uncle Larry's Avatar
Uncle Larry
Aluminum finish ... Black Finish ... Just the polished portion of the Black fin ... Pictures
Old Aug 29, 2023 | 02:51 PM
cj24's Avatar
cj24
I can provide a picture later, but yea it's just the black fins that are affected - inner and outer. Its on a sportster, so the entire fin area is black - no polished edge.
I would think something that works against carbon would work.
Old Aug 29, 2023 | 04:54 PM
eaglefan1's Avatar
eaglefan1
An all purpose cleaner will work, especially if able to get some off. Use one that is designed for automotive use. Most all companies make the. I buy it by the gallon and dilute it to what I need. Dont go crazy and spray it with full strength right away, if you are able to dilute it try what the manufacture suggest as the weakest strength first then move up as needed. Also you will some brushes. Lots to choose from and a wheel brush, barrel brush, could do the job.
Old Aug 29, 2023 | 04:58 PM
kel03's Avatar
kel03
Maybe before and after pictures would be great.
Old Aug 29, 2023 | 05:47 PM
cj24's Avatar
cj24
Thanks guys, I will try a diluted auto cleaner first. Here is a pic
Old Aug 29, 2023 | 06:03 PM
Uncle Larry
While I don't have a suggestion on what cleaner solution may be the best, be careful not to get too aggressive with the brush etc
Old Aug 29, 2023 | 06:40 PM
cj24's Avatar
cj24
Agree, will work a small area first and see what works best... start with mild methods first.
brad75raiders
EVO
May 26, 2018 01:06 AM
Tucker99
Jul 7, 2014 02:05 PM
scratchpad
Feb 19, 2012 06:56 PM
MxNut
Exhaust System Topics
Sep 29, 2011 05:58 PM
crazytrain69
Jul 16, 2009 10:11 PM
