Vivid Black issues
I picked up that Honda-branded Glare pro Polish I mentioned via PM on eBay for $16.50 + $6.50 shipping. She doesn't take PayPal so after a few inquiries we settled on an alternate method. Got the stuff in 2 days! Looking forward to doing a few test spots this weekend.
TL
TL
I would find a test spot rub it in like compound until it's gone. Repeat if needed (at least once probably twice) then finally put it on like a layer of wax and buff off. It is not the shiniest stuff on the shelf but if it can remove rub marks and help make the CC stronger that would be a good thing.
TL
Thanks again for the correction.
A little additional info on the Vivd Black... the tin is the main PITA. The fiberglass/plastic isn't bad at all. The plastic stuff comes out of Wisconsin, the tanks are formed and painted in York. Even if it's the same formulation the paint and CC isn't from the same mix. I don't know if that would account for the variance or whether the paint takes on different properties on different surfaces. Funny, the tin's CC polishes like a harder finish. You've got to work to remove defects but it swirls so damn easily. Go figure.
I just peddled a used-once Flex 3401 DA. Nice machine but being limited to large pads and the lack of an interchangeable backing plate was a serious handicap for the way I used it.
TL
TL
by finishing off with E Z cream glaze and then Blackfire Wet Diamond.
