My favorite product for cleaning black paint is...
1. Don't use circular motions. Use side to side motions.
2. Don't apply a lot of pressure to the paint. Dragging the towel across the paint will remove most dust and grime.
3. Use 100% cotton towels. Remove any tags on the towels (tags will scratch the paint). Wash them after every use.
4. Use a leafblower or air compressor to blow off excess water instead of a towel.
I have more tips but they are really ****. Let me know if you want to hear them?
If you are talking "cleaning" the paint specifically I use 3M Imperial Hand Glaze.
For the swirls as far as OTC products, your best solution will probably be Mequiars ScratchX and then go to #2 and then #3.
Now I'm not saying its better than anything else out there because I've not owed a black bike before so I've never needed something to hide swirl marks before.
I have used it on my bike as well, and I can honestly say that the results are amazing. The finish is very very smooth and the paints looks wet, like you could stick your hand in it. Now, with that said, everyting that I drive is black, my wife owns a dark red vehicle and it works well on it too. It seems that it works better on the darker colors. It is very easy to use, no drying time, just wipe on and wipe off. The cleaner is non-abrasive liquid. It does reccommmend that you use a "back and forth" movement not a circular movement when applying and removing. I generally apply a couple of coats when I wax.
As a side note........it works great on my slipons as well
Just my '02 from trying numerous products for black paint..........good thing I found one Im happy with, .....many more bottles/cans of wax and my wife was on the verge moving me into the garage........well.....my bike IS there.....lololololol.
Good luck!
