Help 2012 wide glide cutting off
Old Nov 15, 2014 | 10:25 AM
redrott's Avatar
redrott
Default Help 2012 wide glide cutting off
I bought the bike used a year ago. It has 8000 miles on it 103 motor with screaming eagle filter and Rinehart pipes. Has download from the dealer. Bike has ran fine up until a month ago. I started it up and it revved a little high for a bit. Then seemed to be fine. I took it on an errand in town and on the way home when I pulled the clutch in and was coasting for a second the rpms dropped to 800 then in the 700's and numbers were flashing on the left side of the tach 4,3,2 Then the bike cut off. It started right back up. It runs fine while you are giving it some throttle or just driving but if you coast for a few seconds it starts to idle down and then it cut off again. It doesn't always cut off but the rpms will drop down to 800 or so everytime. If you come to a stop it will idle back up to 1000?
You can sit at a stop with the clutch in and it will idle all day. Seems to be some issue with it coasting with the clutch in??
Any help before I have to take it to the delear would be appreciated.
Old Nov 15, 2014 | 11:49 AM
nevil's Avatar
nevil
Before you take it to the dealer go over all the simple stuff. Check battery cables and especially the ground connection, condition of fuses and relays.
Try cleaning the IAC.
Old Nov 15, 2014 | 10:34 PM
razors edge's Avatar
razors edge
fuel filter maybe
Old Nov 15, 2014 | 11:29 PM
Pipedope's Avatar
Pipedope
Check fuel pressure. symptoms of a hole in the fuel line.
Old Nov 17, 2014 | 08:32 PM
oct1949's Avatar
oct1949
True on less than full tank. usually it will also cut out when getting on it...
Also usually happens when gas is about 2 gallons after filling tank full .. and never with full tank...
Old Nov 18, 2014 | 09:40 AM
redrott's Avatar
redrott
How do I check the fuel pressure?
Old Nov 18, 2014 | 12:08 PM
enodrano's Avatar
enodrano
Sounds like a fuel problem. If you have a damaged fuel line you will smell gas. To check the fuel pressure you will need a inline fuel gauge:
Use a fuel stabilizer with injector cleaner and change the filter if the pressure is low. Also, performance tuners usually have a setting for how much fuel is provided when slowing down. The setting is a fine balance between stalling and popping and backfires. You said you have a download from the dealer which makes me assume you don't have a tuner but you may want to look under the seat to be sure.
Old Nov 19, 2014 | 08:26 AM
redrott's Avatar
redrott
Definitely does not have a tuner on it. I will check the fuel line and pressure. I am wondering what is up with the number flashing beside the rpms when it starts to drop. Is that a code from the factory or a warning of some type?
Old Nov 19, 2014 | 08:36 AM
nevil's Avatar
nevil
Check for codes.
mikidd71
General Topics/Tech Tips
Apr 8, 2019 05:56 PM
O-SiderRider
Dec 5, 2017 06:06 AM
clap
Oct 1, 2015 12:50 AM
davefromholz
Jul 22, 2011 08:20 AM
Toe Knee
May 1, 2009 08:51 PM
