O2 sensors
Old Jan 7, 2015 | 08:05 PM
motorcycle's Avatar
motorcycle
Default O2 sensors
08 fatbob, v & h 2in2, dn air fltr, am puttin in se 255 cams, was wondering to plug 02 sensors, my friends have theirs plugged per exhaust instructions, forgot to mention i have v & h fuel moto, plugged or not? Thxs for the help
Old Jan 7, 2015 | 08:38 PM
target64's Avatar
target64
what are you using for a tuner? v&H fuel moto ? if the o2 sensor are not hooked up on stock ecm you will set a check engine light.
Old Jan 7, 2015 | 08:58 PM
maddghost's Avatar
maddghost
it isnt the pipes which decide wether or not you can eliminate the O2 sensors it's the tuner. If your tuner does not come with O2 sensor eliminators you will need them to feed info back to the ECM as mr. target pointed out. You see the electronic ignition makes minute changes as you run to adjust itself for air temp, altitude, and fuel octane differences. So unless your tuner specifically states to remove their use I say plug them in. I know the old dynojet pcV's have eliminators, in that case you have to unplug them because the pcV takes over the ECM and feeds it's own information to it.
I don't know what a "V&H fuel moto" is they are two different companies.
bisache
May 27, 2017 12:38 AM
sud55
May 22, 2013 06:39 AM
WideGlideFever
Jan 22, 2013 01:26 PM
ash uk streetbob
Jul 9, 2012 09:27 PM
Comingapart
Exhaust System Topics
Jul 14, 2010 10:50 AM
