splice electrical
Old Jan 10, 2015 | 02:07 PM
skinman13's Avatar
skinman13
Originally Posted by Jason Oates
Posi-Locks and Posi-Taps are absolutely awesome! They even have some "sealed" versions that are water-resistent. I've used these a ton recently on my bike and with backup camera installations on three cars now with no concerns. Best of all, they're reusable should you need to make future modifications! No more needing to cut your wires down further. Highly recommended! J&P Cycles has them for probably the cheapest that I've found so far.
If this method works for you, then more power to ya...but this splice method is almost as bad as just twisting the wires together and wrapping with tape...I have traced down more open circuit and intermittent problems that were caused by failures of these two methods of splice connections than any other...
Old Jan 10, 2015 | 05:52 PM
apetterez's Avatar
apetterez
Default how to route wires.
What is the best way to route your wires to the side mount liscense plate. I dont think its smart to splice into main wireing harness so that means im splicing at the tail light. What is the best way to send wires from tail light to axel nut liscense plate
Old Jan 10, 2015 | 08:48 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Use a sheath flexible wound SS cable shield. http://www.mcmaster.com/#standard-ca...eeving/=vevqzu reference http://www.mcmaster.com/#1478t1/=vevrl6 Drill entrance holes and flare shield on back side. Do your homework carefully and mock it up on bike including the fasteners that retain it to the bike..
krakenmoto
Apr 6, 2017 03:21 PM
raptoid780
Jul 28, 2013 06:33 PM
DaveClendenen
Aug 11, 2012 07:36 PM
voudoujoe
Jun 30, 2011 07:22 AM
Fupl18
Feb 9, 2009 03:49 PM
