FXD gauge back light stuck on
Old Jan 17, 2015 | 09:23 PM
sportruck00's Avatar
sportruck00
6th Gear
Default FXD gauge back light stuck on
Hello - have a 2010 FXD. Went out to the garage this evening after a short ride today and noticed my speedometer gauge light is stuck on with the bike shut off. Any thoughts? I played with the trip button hoping something was going on there with no luck. Also a few rotations of they key in the neck ignition without any luck! Last attempt was disconnecting the speedometer itself. After re-plugging in the speedometer back light is still on and fully illuminated even when the bike is properly shut off through the neck ignition..
Old Jan 18, 2015 | 06:36 AM
wastedranger's Avatar
wastedranger
Did you wash it? Mine did this because the switch got wet inside. Dried out and worked fine ever since.
Old Jan 18, 2015 | 11:02 AM
sportruck00
6th Gear
I did. Hoping that is the case. I usually take pretty good caution around the controls and don't generally overly soak that area of the bike. We'll see if all is well today!
Old Jan 18, 2015 | 03:48 PM
2500hdon37s's Avatar
2500hdon37s
this will make it go out.
GMRO
Feb 24, 2019 01:34 PM
Pirish
May 19, 2016 06:12 PM
DISTURBEDRYAN
Jul 2, 2014 09:22 PM
DISTURBEDRYAN
Welcome Area Only
13
Jun 14, 2014 09:31 PM
c6cjames
Aug 27, 2008 07:55 AM
