splice connectors
Old Jan 18, 2015 | 04:10 PM
apetterez's Avatar
apetterez
Default splice connectors
Installed the heat demon heated grips. It calls for these connectors inside the bars and the red clip connectors under th3 seat to tap into the accessories wire orange white.
My question is have any of u guys used these conecctors if so what do u think about them. Im kind of worried
Old Jan 18, 2015 | 04:14 PM
apetterez's Avatar
apetterez
Here is a picture of the connectors
Old Jan 18, 2015 | 04:57 PM
JohnMn's Avatar
JohnMn
I've used them in auto applications without trouble, just take care when you do the install to get a clean "pinch" and don't bugger the plastic so it'll still clamp to close properly.
If you wrap the splice to other wires with tape so it doesn't wiggle/vibrate all over the place you should be golden,
Old Jan 18, 2015 | 09:59 PM
Nitro 54's Avatar
Nitro 54
Myself I would prefer soldered wire ends with shrink wrap around the joints. Let us know how the heaters work for you. I'm interested in the Heat Demons also.
Old Jan 19, 2015 | 09:05 AM
bobnehoc's Avatar
bobnehoc
I would solder and shrink wrap. There is to much vibration and I would not trust crimp connectors like that.
Old Jan 19, 2015 | 09:13 AM
4_stroke's Avatar
4_stroke
The "splice" thread
https://www.hdforums.com/forum/dyna-...lectrical.html
Old Jan 19, 2015 | 10:32 AM
skinman13's Avatar
skinman13
I have never used them, and never will use them not even for a temporary emergency repair. You would be better off just twisting the wires together and wrapping it all with electrical tape before using those things...
If you cannot make solder splice covered with shrink tubing, then use an insulated crimp splice and use the proper crimping tool.
just my dos centavos...
Old Jan 19, 2015 | 12:55 PM
apetterez's Avatar
apetterez
The heaters work great. Im going 5o leave the connectors for now.
Trying to splice the orange white wir3 with solder and shrink tube is impossible. No room under the seat
Old Jan 19, 2015 | 01:02 PM
TSheff's Avatar
TSheff
Yep - If you're going to do an upgrade take the time to do it RIGHT, not Easy, Worst thing in the world is to get left or have a failure because of a bad connection. Hard to find on the road.
Old Jan 19, 2015 | 01:05 PM
TSheff's Avatar
TSheff
If it's too tight add wire.
