Rifle fairing install suggestions
Old Jan 19, 2015 | 02:48 PM
Bardo805's Avatar
Bardo805
Default Rifle fairing install suggestions
Got a 2014 street bob with the 49mm forks. Not sure i got the right hardware. Anyone got any pics or suggestions for install of fairing. I have seen clamps used instead of some of the provided hardware. Thanks in advance
Old Jan 19, 2015 | 03:53 PM
Bardo805's Avatar
Bardo805
Well did a little research going to use fork clamps for the upper part of the fairing instead of using the triple clamp brackets to the pinch bolts cause i see now way in hell to attaching them unless i do some fab work to the brackets themselves. But if any one else has any other suggestions or fork clamp brands to use please drop me a line.
Old May 19, 2015 | 09:59 PM
oldlefty's Avatar
oldlefty
well i used some HD locking clamps to mount mine. i decided to make it totally removable so i can easily work on the bike and clean off all the bugs. so i used four clamps and drilled two holes, one in each lower corner. (not for everyone but that's how i wanted it.)
Old May 20, 2015 | 01:20 AM
OG1's Avatar
OG1
Any 49mm clamp will work but you will want the longer collet struts from Rifle to do the job right. The included ones are just a bit too short. I used just the top portion of the longer ones.
Old May 20, 2015 | 02:39 AM
Stych's Avatar
Stych
VERY nicely done!!! I like my Rifle fairing, but the instructions/hardware... Grrr. Looks like I found next winters project, damn you ;-)
Old May 20, 2015 | 06:18 PM
Rowdy Fetus's Avatar
Rowdy Fetus
Oldlefty - do you mean you drilled right into the fairing? Did you just line it up and go? I have the same clamps that I'm going to use as well, did you need the longer collet struts or just whatever it came with?
Also - what bags you got on there? They look great!
Old May 26, 2015 | 04:34 PM
b2inUT's Avatar
b2inUT
I'd like more information/pictures on this setup, too. OldLefty, can you post more pics? Thanks.
Old Sep 2, 2016 | 04:58 PM
Fraser's Avatar
Fraser
4th Gear
Default My rifle
I mounted as quick detachable with Memphis Shades brackets for 49MM forks. Cut and welded so fits snug around headlight.Can pop on/off for cleaning. I mounted half a plastic tray inside as a shelf with foam covering(looks good and practial as small storage spot.
Old Jul 10, 2020 | 07:57 PM
2019StreetBob's Avatar
2019StreetBob
Stage III
Default FXRT Fairing on 2019 FXBB
Sorry, had a brain fart and posted in the wrong thread.
Last edited by 2019StreetBob; Jul 10, 2020 at 08:52 PM. Reason: Revise/correct text.
Old Nov 3, 2020 | 07:10 AM
Frank_the_Beard's Avatar
Frank_the_Beard
More like the Oldrighty
