Adjustable Pushrods Bleed-out Help
Old Jan 19, 2015 | 05:15 PM
HighonHarley's Avatar
HighonHarley
Default Adjustable Pushrods Bleed-out Help
I was installing adjustable pushrods, and adjusted both (on rear cylinder). I then remembered after about 5 minutes you could only do one at a time so I loosened the intake and left the exhaust bleeding. The exhaust bled out after 20 minutes and spun freely so I adjust the intake 20 flats at 0 lash, waited 20 minutes and it was still tight. I'm assuming that was a little too far since it had started bleeding before, so I backed it off 3 flats until it spun with the same ease of the exhaust. Am I correct with what I did or am I screwed now? Is there a way to check before starting the bike?
Old Jan 19, 2015 | 06:10 PM
h-d wrencher's Avatar
h-d wrencher
I would loosen them all up and start over. Some of mine bled in 5 minutes and some of them took 15 minutes.
Old Jan 19, 2015 | 07:01 PM
JMummery's Avatar
JMummery
What pushrods are you using?
Old Jan 19, 2015 | 07:43 PM
HighonHarley
They're S&S adjustables. I see the error of my ways after I thought about it for a few minutes. You're right HD Wrencher, I'll just reset both rods and let the lifters go back to their natural resting state and redo them. Thanks.
pop48
Engine Mechanical Topics
Jun 18, 2014 09:26 AM
ncracer86
Feb 26, 2014 04:22 PM
ncracer86
Feb 24, 2014 09:08 AM
mbierbac
Exhaust System Topics
Feb 29, 2012 11:56 AM
RidemyEVO
EVO
Apr 4, 2010 09:42 PM
