Help with suspension
Old Jan 31, 2015 | 10:30 AM
_wcc_'s Avatar
_wcc_
Default Help with suspension
Anyone have suggestion on rear shock length for a 2005 fxdl?
Gonna raise the front back to standard i think with some new springs, already have the racetech gold valve emulators installed.
So i'm thinkin, maybe some Ohlins shocks in the rear or works black trackers
But the biggest question i have is which length i should choose, 12.6" is what i'm thinkin about, anyone with a low rider, that have any input?
Old Jan 31, 2015 | 11:13 AM
_wcc_'s Avatar
_wcc_
Btw, just installed some new forbidden bars and riser, will put on a quarter fairing too
Old Jan 31, 2015 | 11:26 AM
0lowrider1's Avatar
0lowrider1
I have a 01 fxdl..I got some JRI B shocks in 13"..love them.didnt raise the bike much at all.really the only time that it looks raised is when it's on sidestand.i got mine from Howard at motorcycle metal, a forum sponsor...love those shocks, I also did the Ricor intimidators and Traxxion straight rate springs. What a huge difference all that made on ride quality and handling..never had ohlins but read alot of good about them..Howard also handles ohlins and will have the right valving and spring rate setup for you...
Old Jan 31, 2015 | 11:49 AM
Racqueteer9's Avatar
Racqueteer9
I put 13" Progressive 440's on my 2005 FXDL last year and am quite happy with them. The extra height stopped the scraping on twisty mountain roads that I like to run on. I'd probably choose Ohlins over Works if price is similar.
Old Jan 31, 2015 | 11:51 AM
_wcc_'s Avatar
_wcc_
Thank you, 13" does not sound bad then, extra shock travel is never a bad thing i guess
Do you have longer fork tubes?
Old Jan 31, 2015 | 12:17 PM
_wcc_'s Avatar
_wcc_
Okey, you don't happen to have a picture of your bike with the 13" shocks?
Do you have longer fork tubes to even out the extra lenght of the rear shocks?
Old Jan 31, 2015 | 01:59 PM
Jackpoticorn's Avatar
Jackpoticorn
I have an 05 low rider as well! Literally just installed my Works shocks last night...just got back from first ride...all I can say is OMFG!!! Night and day difference between my old progressives and these works. handling is VASTLY improved as is stability at speed and comfortability of the ride.
I will say though, I'm a shorter rider so I went with the 12.1" length and already dragged a peg during a low speed turn. Works has a 30 day ride satisfaction window and I may exchange these for the 12.6" length
Old Jan 31, 2015 | 03:11 PM
TMike84's Avatar
TMike84
I've got the best 13" JRI B shocks on my 01 FXDXT. I also got them from Howard at Motorcycle Metal. The shocks are great, good price and easy to set up. Also Howard will set up spring rate to you and your riding style
Old Jan 31, 2015 | 04:06 PM
0lowrider1's Avatar
0lowrider1
No mine are stock tubes..your not talk in much of an increase by the time you set correct sag..but it sure does ride soooooo much better
Old Jan 31, 2015 | 07:48 PM
Racqueteer9
Sorry no. I need to get out and take some photos once it warms up. I don't think the extra 1" would make enough difference in frame geometry to be easily noticeable. I did adjust forks as low in triple trees as possible when I added progressive springs up front, the same time I changed rear shocks. This was mainly done to firm up the front and reduce brake dive but probably raised front 3/8 or 1/2".
