'15 Low Rider "adjustable" risers
Old Feb 7, 2015 | 03:22 PM
Mchad's Avatar
Mchad
Default '15 Low Rider "adjustable" risers
Been thinking about a new low rider and am concerned about the adjustable bars. Specifically wondering if/how they could be replaced with T-bars if I wanted to. Looks a fair bit different then a standard mount. Anyone know?
Tx
Old Feb 7, 2015 | 03:48 PM
dyna bomb's Avatar
dyna bomb
im doing the swap right now on my 14 low rider with la choppers club bars hi, and the risers bolt right up to the triple tree no prob just like any other risers would so the swap is no issue but you will need all new cables and lines if you go above 10 inches the club bars have a 13 in end rise and i needed all new stuff! hope this helps
Old Feb 7, 2015 | 04:23 PM
Mchad's Avatar
Mchad
Definitely does brother. Thanks.
Old Feb 9, 2015 | 11:05 AM
kit05's Avatar
kit05
Dont forget if you change bars you will also need a new headlight bucket bottom mount. also keep in mind if you have ABS you will need new line with anything over 8" tall.
Old Feb 9, 2015 | 11:51 AM
pab3rd's Avatar
pab3rd
Ditto. You can get a headlight mount from DK Customs. That is what I used. Also if over 10" on the bars; even without ABS the brake line will need to be replaced.
Old Feb 9, 2015 | 04:09 PM
dyna bomb's Avatar
dyna bomb
Do you have the part number to that headlight mount from do customs I can't seem to find it? Thanks
Old Feb 9, 2015 | 08:00 PM
pab3rd's Avatar
pab3rd
http://www.dkcustomproducts.com/Modular-Headlight-Relocation-Bracket-Sportster-Dyna-Softail-DK-HL-BRK-MOD.htm
Old Feb 11, 2015 | 11:17 AM
kevinckb3's Avatar
kevinckb3
does this do away with the brow over headlight? i've been wanting to do a 2" tank lift and the stock setup wont allow it .. then I started thinking about swapping the mounts on the triple tree . i am away from my bike for awhile so I can't run out and check
thanks
K
Old Feb 11, 2015 | 11:59 AM
reedyjm's Avatar
reedyjm
thanks
K
Yes Kevin, the headlight brow is integrated into the clamps. If you add different clamps, it will eliminate the headlight brow and you will have relocate the headlight. I used the DK Customs kit and just mounted the stock headlight to the bottom tree.
Old Nov 22, 2016 | 05:48 PM
PacoElProfesor's Avatar
PacoElProfesor
Has anyone mounted the headlight on the top tree using the DK kit ? if so, where do you mount the brackets? on the riser bolts ?
