Hesitation or feels like it died
Old Feb 8, 2015 | 07:03 PM
Jaystn62's Avatar
Jaystn62
Default Hesitation or feels like it died
Was out for a ride on backroads yesterday. Hammered on bike once through first and second then let off. All seemed normal then twisted throttle and bike balked or seemed to die. Let off throttle and it ran. Bike did this a couple times then picked up and took off like normal. After that noticed once in a while it would hesitate in second around 2200 to 2300 rpm at a steady state. I'm running a FP3 with K&N intake and a set of Rinehart slipons. Anyone else have this experience? Any advice? Thanks in advance.
Old Feb 8, 2015 | 11:22 PM
apetterez's Avatar
apetterez
Im experienceing something kind of similiar. Looks like a leak on the manifold where it butts up to the heads
Old Feb 8, 2015 | 11:41 PM
John_K's Avatar
John_K
That (intake seals) was a common maintenance item on my Sportster, replacing them every two-three years was cheap and just good preventative medicine. Don't know about EFI but carbed bikes would run like **** if there was any sort of intake leak, AFR way out of whack. Thanks for the reminder, another item on my winter to-do list.
Old Feb 9, 2015 | 10:49 AM
mrfikser's Avatar
mrfikser
I would check all of your electrical connections, esp. the battery..maybe something is loose somewhere
Old Feb 9, 2015 | 11:14 AM
wilddave's Avatar
wilddave
How old/fresh is your gas?
Old Feb 9, 2015 | 04:11 PM
Jaystn62's Avatar
Jaystn62
I had a Sportster before this bike and totally different hesitation. Gas is fresh had just filled up before riding. Thinking about trying a different map on the FP3 after I check connections and such. Acts like it's not getting fuel to me.
Old Feb 9, 2015 | 10:50 PM
John_K's Avatar
John_K
MAP sensor is another potential culprit. If it fails to deliver the proper signal your ignition will not advance as needed - result is loss of power. My Sporty had this trouble as well. You can save a few bucks buying one at your favourite auto parts store, you'll need to do the cross reference though.
aGoodRogering
General Topics/Tech Tips
May 8, 2018 01:13 PM
misfitJason
Jan 31, 2017 09:58 AM
allaco
Exhaust System Topics
Oct 15, 2011 05:54 PM
BluePotato
May 13, 2008 07:42 AM
2BKFXDL
Nov 18, 2005 11:07 AM
