Missing and Popping
Old Feb 10, 2015 | 07:06 PM
PapaBranch's Avatar
PapaBranch
2nd Gear
Default Missing and Popping
I have a 2003 FDX Dyna Super Glide. When it idles , it misses and pops. When I throttle, it is OK.
Any suggestions ?
Old Feb 10, 2015 | 09:15 PM
apetterez's Avatar
apetterez
Mine is doing the exact same thing. I used carb cleaner and sprayed some around the manifold where it attachs to the heads and the idle sputtered letting me know u have an air leak. Will be fixing this weekeNd. Check yours with carb cleaner around exhaust flanges and manifold
Old Feb 10, 2015 | 09:17 PM
John_K's Avatar
John_K
You can start by adjusting the idle mixture a little richer.
No... forget the carb for now.
Start by replacing the intake seals, see if that improves the situation.
Then adjust the idle mixture.
lowflyer
Carburetor Related
Aug 18, 2014 08:20 PM
awstunn
Dec 5, 2012 01:45 PM
indianaironhead
Ironhead
Jul 3, 2012 06:00 PM
Sho71vel
Shovelhead
Mar 20, 2012 02:47 PM
jermil32
Ironhead
Oct 25, 2007 01:47 PM
