Vibra TECNICS
Old Feb 20, 2015 | 03:46 PM
DesertDyna's Avatar
DesertDyna
Originally Posted by Jesse_81
I'm not seeing how this would replace a true-track. True-Track being mounted to the rear of the bike to the trans to rid of the "yaw" motion in the motor/swingarm. Not saying this front system isn't a good idea and ridding the bike of the shitty front rubber mount as well as some allignment problem.
THe primary part of TrueTrack or Sputhe is the FRONT stabilizer. The rear is nice (I have one), but if you have a good rear mount, is not as important as the front. Having the rear without the front is virtually useless. That said, I also replaced my true track front stabilizer with the Vibratechnics mount, because they do the exact same thing (eliminate lateral movement), and as mentioned above, the VB mount isnt an "add on" like the TT. Anyone want a front True Track? its for sale. As soon as I replace my rear mount with a urethane one....the rear TT goes too.
Old Feb 20, 2015 | 03:54 PM
2500hdon37s's Avatar
2500hdon37s
The true track for Dynas is a front and rear stabilizer kit. The front is where the majority of the problem is with the Dynas because of the swing arm being mounted to the transmission case not the frame, and then the transmission is solidly mounted to the crank case and its only got a mushy motor mount in the front holding it on, and the swing arm is going to have a lot of leverage on that mount.
There was a member here that did the Vibra front mount, rode and then put on a Sputhe or true track rear mount and said the handling difference of adding the rear stabilizer was nearly non existant and not noticeable. That said I think it's still smart to pick up a rear stabilizer, but I think the Vibra-technics design is a much better solution to the main problem source that comes from the original motor mount which the other two build upon.
Old Feb 20, 2015 | 03:57 PM
robbyville's Avatar
robbyville
Originally Posted by 2500hdon37s
I emailed them and they said it fits 2014's. product webpage just hasn't been updated.
Thank you sir!
I'm curious from those who did this update as well. Did you essentially do them out of necessity (old mount was shot), or because it aids in comfort?
Old Feb 20, 2015 | 05:54 PM
monster715's Avatar
monster715
Originally Posted by robbyville
Thank you sir!
There's plenty of guys out there that replaced almost new mounts with the vt mount. Another plus to the vt mount is that the stabilizer is hidden and not hanging off the front of the bike, some don't mind the that, but it's still a plus. Myself, I have mixed feelings about the mount. It definitely absorbs vibrations better, but I had issues with my pipe slightly hitting my mid control peg mount. They have since, lowered the mounting block so the motor now sits a little lower in the frame than before. Even with that I still had issues but I spoke with phil at vibra techincs and he said if I had the exhaust adjusted to a sagging front mount then of course it's going to hit the peg so I just need to re adjust. Makes perfect sense and I didn't even think about that. We'll see when I get the motor back together but one thing I can say for sure is that their customer service is top notch. These guys stand by their product and are happy to help
Old Feb 20, 2015 | 06:01 PM
robbyville's Avatar
robbyville
I was reading about just that topic a bit ago. I guess Tomt also mentioned it and that the answer was having someone sit on the bike when torquing that center bolt for the last time thus pulling the engine back.
This is a pretty interesting one. I don't have any stability problems with the type of riding I do, but similar to what Matt had mentioned in his very first post on his install there are times where all I can make out of my left hand mirror are shapes. I can only imagine how much more comfortable this would be on the hands and such after a long ride. I'm going to keep reading and watching this thread but I think I smell my next "comfort" mod...
Old Feb 20, 2015 | 06:14 PM
tomt's Avatar
tomt
I had the same problem. After I did the video I took the bike for a short ride. When I came back I saw the top front heat shield hit the frame.
I torqued the center bolt while the bike was still in the air.
What you have to do is have someone sit on the bike before you torque the center bolt down. This pulls the engine back. I haven't tested this fix yet. As soon as the weather changes I'm going to take the bike for a long test ride.
Old Feb 20, 2015 | 06:19 PM
tomt's Avatar
tomt
You beat me to it.
Old Feb 20, 2015 | 07:37 PM
Max Headflow's Avatar
Max Headflow
Custom Cycle Engineering will be making one also.. It will use a stock FL style front mount.. You can get em cheap from drag or use another after market one like V thunder or glidepro.. Not sure what the final price will be..
Old Feb 20, 2015 | 08:15 PM
br549A1's Avatar
br549A1
Vibratechnics makes a huge difference in stability.
Old Feb 20, 2015 | 08:43 PM
John_K's Avatar
John_K
Thank you sir!
When I bought my bike, the front was sagging so much the front header was touching the frame. After reading the bad reviews of the stock mount, and previous experience with the rubber on my Sporty... there was no way I was paying for OEM motor mounts if there was any aftermarket equivalent available.
I lucked on my timing with the VT mount just becoming available, and after the preliminary reviews I was sold. Anything's better than the OEM crap as far as I'm concerned.
