Oil filter headache
Old Apr 22, 2007 | 02:24 PM
rumblebee's Avatar
rumblebee
Default Oil filter headache
[:'(]Has anyone came up with a way to pull the oil filter off and not get it all over the front of the engine. Harley's engineers didn't think on that design too long.
Old Apr 22, 2007 | 02:51 PM
DGlide04's Avatar
DGlide04
Default RE: Oil filter headache
The best/cheapest way of doing that I've found is to take a piece of newspaper and fold it up the long way into sort of a funnel and put it under the filter. As you unscrew the filter, the oil (usually) runs down the paper into a pan or whatever you use to collect the oil Foolproof, no, but it's quick and cleanup is minimal.
Old Apr 22, 2007 | 02:54 PM
anubisss's Avatar
anubisss
Do a search, there are a lort of different methods. One invlves using tin foil as opposed to newpaper, another involves poking the end of the filter and letting it drain into the drain pan, another method cut a 2 liter soda bottle down and put that around the filter so when you take off the filter the bottle catches the oil.
Old Apr 22, 2007 | 06:50 PM
tireater's Avatar
tireater
I use plastic soda bottle method - seems to work...
Old Apr 22, 2007 | 07:04 PM
nvsteve's Avatar
nvsteve
I used a plastic ziploc bag the last time and it worked great.
Just get the filter started enough that you can turn it by hand, slip the bag over it and spin it off.
Old Apr 22, 2007 | 09:06 PM
phreak's Avatar
phreak
ORIGINAL: tireater
Same here.
Old Apr 22, 2007 | 09:42 PM
Jehu's Avatar
Jehu
And to think that I was onto something with the "let it drip all over everything and then spray with brake parts cleaner" method.
Old Apr 22, 2007 | 11:03 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: Jehu
That's exactly how I usually do it.............. Thanks for the great ideas!!!
DougJ (not Bob)
Old Apr 23, 2007 | 12:31 AM
dog06bob's Avatar
dog06bob
Not a perfect science man! Basically sucks! I stuff a rag under it, helps some, but still makes a mess.
Old Apr 23, 2007 | 02:56 AM
mud's Avatar
mud
ORIGINAL: rumblebee
This is your first machine. Right??
If this is your biggest problem,
then you are on easy street.
You have no idea what the engineers have done for you.
Shoulda been here 40 years ago,
then you woulda been peckin a buncha more keystrokes.
mud
