Help...knocking sound and smoke
Old Apr 9, 2015 | 09:12 AM
  #31
divebum33's Avatar
divebum33
No mention of adjustable push rods...
https://www.denniskirk.com/rocker-bo...prd/495162.sku
Old Apr 9, 2015 | 05:49 PM
  #32
ChefRex's Avatar
ChefRex
Originally Posted by Stiggy
I would assume that the ad for the aftermarket boxes would specify that adjustable pushrods would be required in order to install the boxes correctly.
Why would they need adjustables? Same item as stock just probably made in Chena.
OP you didn't answer my inquiry
Old Apr 9, 2015 | 05:50 PM
  #33
Harleycruiser's Avatar
Harleycruiser
You should not need adjustable push rods.
My guess is that you did not let your lifters bleed down before you rotated your motor and you have bent a exhaust valve and the push rod, hope I am wrong. That is why your exhaust is getting red.
Were you on the cam base circle and top dead center with the piston for each cyclender?
Please take note I am not an engine expert I do not know if that is problematic with stock cams like aftermarket .
Old Apr 9, 2015 | 07:11 PM
  #34
Stiggy's Avatar
Stiggy
He shouldn't need adjustables. I was responding to another poster suggesting that that was what he needed with these boxes. I responded that the ad would say so if they were required. It doesn't.
Personally, I also suspect that a valve may have tapped a piston and that's why the noise and other symptoms occuring now. I hope I'm wrong. Usually that cylinder won't even fire when a valve gets bent. (Mine didn't.)
dynasnow
Engine Mechanical Topics
Sep 29, 2017 09:56 PM
Bowhunter8607
Jan 25, 2016 08:51 AM
LAZ_Rocker
May 3, 2015 09:36 PM
frozensoul
Sep 24, 2011 12:59 AM
masar
VRSC Models
Feb 22, 2011 02:43 PM
