Evo cam or head work?
Old Jan 4, 2020 | 08:39 AM
dracer's Avatar
dracer
it is the heads that make the power and it is the cams that dictate where in the rpm the power will be. when changing cams you are limited by what the heads can handle. if you want to make good reliable power you should get the heads done first, then pick the cam that will put the power in the rpm range you want to ride, now get the compression the cam wants with a bore or milling the heads. to make it all come together and run like you want it will take some planning. talk with who is doing the heads and your combination will work much better. going out and getting parts from all over the place an hoping they will work is a waste of time. Make a plan, save your money and just do it. anymore questions just ask. danvanceracing.com
Old Jan 6, 2020 | 05:35 AM
brownie4412's Avatar
brownie4412
Wait till you can swing it and do both at the same time. You’ll be glad you did
Old Jan 11, 2020 | 07:54 AM
sharkey's Avatar
sharkey
And I say, don't be oversold. Stock CV is fine, stock heads too IF you're not revving the engine lots...combined with a good torque cam, decent pipes and maybe a good tune. I've been there with the triple digit HP/TQ builds and in fact, for my riding style, I wouldn't do it again. While it was nice to clobber other bikes on the street, all I really needed was to be able to clobber minivans and cruise smooth and reliably.
machinehed
Jan 6, 2020 06:42 AM
mdazb
Exhaust System Topics
Aug 9, 2012 05:33 AM
mav7500
Shovelhead
Dec 25, 2007 02:31 AM
2005flstfi
Oct 20, 2006 12:22 PM
nfe
Jun 17, 2006 04:41 PM
