Removing Baffles: Bad for the engine???
Old Apr 16, 2015 | 11:21 AM
Warp Factor's Avatar
Warp Factor
Originally Posted by FrankDaTank182
And as far as warranty. if you ever have an issue they have to directly link it to the modification you performed to deny you warranty.
Technically, yes. But they can actually do anything they want about the warranty, unless you have the time and money to battle Harley in court
Old Apr 16, 2015 | 12:16 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Edsal
Hey guys. I just bought a new 2015 Wide Glide a couple of weeks ago. The stock pipes sound like #@%$!!! I'm sure you all can relate. I've been reading all over the forum trying to find an answer to this question but no luck yet.
I took a ride over to the local dealer and had a conversation with the service manager about mods. We talked about a few different things I plan to do to the bike and they asked what I planned to do with the pipes. I explained that I recently heard of the DK Thunder Torque Inserts and I planned on removing the baffles and installing those instead. The SM's eyes got about the size of basketballs and said "Don't do that. It'll ruin your engine and void the warranty!".
This is the first I've heard of this. Can anyone tell me if this is true? Thanks in advance!
A few thoughts-
I have never heard of ANY exhaust change ever being the basis for denying a warranty claim.
The dealer, and HD Corp. can deny a claim for whatever reason they choose..does not mean they are right, does not mean it is worth it to fight them either.
There is Nothing about removing the baffles from stock exhaust and replacing with patented TTI's that is even remotely damaging to the engine.
If I ever had a warranty claim that involved the engine, I would just put the stock A/C, stock exhaust and stock tune on it before taking it in. That way I would not have to deal with any possibility that someone would try and deny a claim.
Regarding performance. If anyone thinks they have modded stock exhaust or slip-ons that will perform better without the Thunder Torque Inserts than with them, contact me directly...I will give you a set for free, If you will go get a before and after Dyno run and provide me with the charts.
We have NEVER seen an exhaust (except for the supertrapp design) that did not benefit from the TTI's.
You can look at some dyno charts at the link below to get an idea of how well they bump the low & mid range power.
http://www.dkcustomproducts.com/Thun...DK-TTI-158.htm
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 16, 2015 | 12:30 PM
Ape_Hanger's Avatar
Ape_Hanger
I have Cycle Shack slip ons with no baffles. Back where they connect to the header, there is an insert with a round metal tab at a 45 degree angle that looks similar to the TTI. Do you think adding a set of TTI's out toward the other end of the slip ons would increase the low and mid range torque without sacrificing sound?
Old Apr 16, 2015 | 12:55 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Sound is subjective. What sounds good to you may not to the person next to you. The W version of the TTI's generally lower the tone a bit, and reduce the decibels by 1-3. So not much difference in volume, and a bit lower tone.
On performance, yes, they will increase the low & mid range torque on your set up. (I ran CS slip-ons on my Sporty for almost 3 years with the TTI's)
Old Apr 16, 2015 | 01:01 PM
rdondes's Avatar
rdondes
Slip-on mufflers with Big City Thunder "Monster Baffles" will give you the sound and performance you are looking for - at a reasonable price.
Old Apr 16, 2015 | 01:17 PM
jdunn01's Avatar
jdunn01
If this helps....
I am running Rush Big Loui's with the baffles removed and the W Thunder Torque Inserts and a FP3 Tuner on a 14 SGS.
The TTI's definitely brought back the Low and Mid-range torque as promised. The FP3 helped even more.
I love the sound... it is much deeper and bit louder.
Old May 3, 2015 | 07:03 PM
on3wego's Avatar
on3wego
So did you remove the baffles? Cause I am thinking of removing mine and I was wondering how much power difference you'll notice.
Old May 3, 2015 | 08:42 PM
TinCupChalice's Avatar
TinCupChalice
Pull the baffles from the stock exhaust, install the DK Custom TTI's and you'll have that low and mid-range performance back along with a much better sound. Follow the links Kevin posted up and watch the videos and check out the dyno charts, the TTI's do work exactly as advertised, I've used them on several bikes and love what they do for the overall sound and the low end performance. Installing them in the stock Wide Glide exhaust with the baffles removed will be an easy job.
This is my '13 Wide Glide, now granted I'm running a V&H Big Shots Staggered full exhaust, DK Custom 587 A/C, and tuning with a Power Vision I purchased from DK Custom with a great map from FuelMoto but the TTI's are doing exactly what they're designed to do, bring back the bottom end performance and deepen the tone of the exhaust. These are W158's with no baffles, she sounds fantastic and the low end and mid-range performance is much improved after removal of the baffles and the addition of the TTI's. Measure your pipe to get the proper sized TTI's, this is the fitment you want, too small and you won't have the improvements you're looking for...
Rcole
Exhaust System Topics
Nov 17, 2014 06:18 PM
Smartbass
May 28, 2013 07:38 PM
Kushman
EVO
23
Jan 23, 2012 03:40 PM
maddawg57
Oct 3, 2009 11:23 PM
ssbogger
May 2, 2008 12:41 AM
