predator motor mounts
Old Aug 22, 2015 | 01:37 PM
  #51
clap's Avatar
clap
Any of you guys that installed your predator mount have any trouble getting clearence between the mount and the plastic that contains all the wires from voltage regulator and a couple more, As soon as I mount the voltage reg back onto frame it pushed the plastic back and makes contact with the mount. I think that is where my vibes in the pegs is comming from. If so what did you do to fix this problem. It is driving me crazy please help asap
Old Aug 22, 2015 | 04:39 PM
  #52
WideGlideFever's Avatar
WideGlideFever
Mine does the same thing, played around for a while and didnt see any way to not make it touch. I just went for a short test ride and didnt notice any extra vibes, hopefully it stays that way.
Old Aug 23, 2015 | 11:25 AM
  #53
stilup's Avatar
stilup
I removed that plastic as it doesn't work with my added Cobra tuner wiring.
I just wrapped all the connections in large heat shrink and secured it to the frame.
Old Oct 15, 2015 | 04:44 PM
  #54
chevito's Avatar
chevito
3rd Gear
have anyone install Predator HDD100M Twin Cam front engine mount
on a 2015 Wide Glide?
is it worth spending the$$$ for this mount
any comments will be gladly appreciated
Old Oct 15, 2015 | 05:53 PM
  #55
Super08's Avatar
Super08
I had mine in two or three days to western Canada as well.
Old Oct 15, 2015 | 09:36 PM
  #56
TXSwede's Avatar
TXSwede
I was just informed I need a front motor mount. Just how much better are these than OEM?
Old Oct 15, 2015 | 09:50 PM
  #57
Super08's Avatar
Super08
I haven't mounted mine yet, but just looking at the design and construction there is no comparison. With my 2014 I will have to bend the plastic bracket that holds two electrical plugs (one for the front oxygen sensor and not sure about the other). This bracket hangs down under the voltage regulator. Some guys just leave it rubbing on the front of the mount but I plan to heat mine with a micro torch to put a permenant bend it it so it isn't rubbing on the mount. One guy just took the bracket off and put some heat shrink around the connectors. This is not a problem on the earlier models that didn't have this braket. It is only found on the later models. You can see the bracket I am referring to in the video below from the 13 to 19 second mark.
Old Oct 15, 2015 | 10:15 PM
  #58
WideGlideFever
Originally Posted by Super08
I haven't mounted mine yet, but just looking at the design and construction there is no comparison. With my 2014 I will have to bend the plastic bracket that holds two electrical plugs (one for the front oxygen sensor and not sure about the other). This bracket hangs down under the voltage regulator. Some guys just leave it rubbing on the front of the mount but I plan to heat mine with a micro torch to put a permenant bend it it so it isn't rubbing on the mount. One guy just took the bracket off and put some heat shrink around the conectors. This is not a problem on the earlier models that didn't have this braket. It is only found on the later models. You can see the bracket I am referring to in the video below from the 13 to 19 second mark.
HDD100M Dyna front motor mount - YouTube
I just left my bracket but it eventually broke after about a week. Took the bracket off, heat shrinked the the two connectors and zip tied them. I actually like the look better without the bracket.
Motor mount has worked flawlessly so far......hopefully for many many more miles to come!
Old Oct 27, 2015 | 09:27 AM
  #59
Super08's Avatar
Super08
I got mine installed yesterday and came up with a solution for the bracket that rubs on the mount.
https://www.hdforums.com/forum/dyna-...l#post14518042
Old Oct 28, 2015 | 07:26 PM
  #60
Super08's Avatar
Super08
I couldn't contain myself, the sun came out and I just had to see how that new engine mount felt. I bundled up and took it out for a ride with it being only 31F outside. It was only a 30 minute ride but all I can say is wow! It has transformed the bike. Where it always felt loose going into corners fast and had a disconnected feel is gone. It is like riding a Japanese bike from back in the 70's or 80's. Steering is instant and direct, even the smallest input is rewarded by an immediate response. It has literally transformed the bike to have lightning fast response. I never realized just how much the bike was wallowing before with the rubber mounted engine/swing-arm assembly until now. I highly recommend this to everyone over the stock front mount.
2002fxdp
Dec 16, 2017 09:45 PM
edjack
Jun 21, 2015 08:59 AM
The Nev
May 27, 2012 05:52 PM
PHA-Q
Dec 1, 2011 05:29 PM
ultra2006
Mar 11, 2007 04:29 PM
