Vacum Leak From Removing Smog Can...
Old Apr 26, 2007 | 07:55 PM
tireater's Avatar
tireater
Default Vacum Leak From Removing Smog Can...
I was mocking up a 2" tank lift today and noticed the tube running from the removed canister to the air intake was open...
Wouldn't this cause motor to have a vacume leak? It has been stumbling at low rpm...Thanks for reply....
Old Apr 26, 2007 | 08:36 PM
nkauf21's Avatar
nkauf21
Default RE: Vacum Leak From Removing Smog Can...
not sure. i pulled mine and i haven't had any problems.
Old Apr 26, 2007 | 09:23 PM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: tireater
Yes, It will give you a vacuum leak. read post #6 for more details https://www.hdforums.com/m_326157/tm.htm
Old Apr 26, 2007 | 09:36 PM
nkauf21's Avatar
nkauf21
i was thinking of the wrong hose untill i read ws6's post. the hose that connects to the intake manifold needs to be plugged. you can cap the port on the intake, i just cut down the line a little bit plugged it, zip tied it to the inside part of the frame and called it good. no problems yet.
Old Apr 26, 2007 | 09:38 PM
tireater's Avatar
tireater
Did can removal a year ago...I just pulled hose off air intake and put rubber cap on it...WHAT WAS I THINKING...?
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
dvsf100
May 21, 2011 12:59 PM
sincityharley
Dec 25, 2010 01:09 AM
msoucy
Aug 9, 2005 02:32 AM
HDF Tech
Engine Mechanical Topics
Jun 24, 2005 06:33 PM
