Sumax bracket review
Old May 26, 2015 | 08:05 AM
Tufel's Avatar
Tufel
Default Sumax bracket review
Installed the Sumax Dyna brackets for quick detach backrests this weekend, 8815D. http://sumax.com/dyna_bags.html
Overall I'm very happy with the brackets. They went on fairly easily. The hardest part, for me, was adjusting the pieces which the quarter turn fasteners attach to. Small spaces are always the worst, IMO. The bags I bought dropped right on and bolt up great.
There were only two issues I'd say were the "fault" of Sumax. First, the supplied bolts were too short. At first I though they sent the bolts for the kit without the detachable backrest. After looking I decided the bolts supplied were the "correct" ones as they had the longer piece for the shock mounts, and the included boots were vacuum packed with the shock pieces. However, the bolts were 1/2 to 3/4 of an inch to short. The bolts I purchased aren't as nice looking as the ones that came with the bags, but the are grade 8 so should be strong enough
Second, a corner had chipped paint, not sure if it was due to shipping or if it came that way. I suspect it was not shipping as the brackets were wrapped very well and padded very well in the box. Also, there was a touch of rust indicating it had been that way for a while. I'll take care of that shortly and it wasn't bad enough to make me want to return the brackets.
Overall based solely upon install and the brackets themselves I'd give them a 9 of 10. Having to do touch up painting and running to get the correct bolts were the only issues but enough to drop the products score. Now for the real test, to see how the hold up.
Old May 26, 2015 | 10:43 AM
blueangel73's Avatar
blueangel73
Pictures, pictures, pictures...................it didn't happen if there aren't any pictures!!!!
Old May 26, 2015 | 10:22 PM
Tufel's Avatar
Tufel
Here's some pictures. I need to get them painted but not bad for a total of 650 so far.
Old May 26, 2015 | 10:23 PM
Tufel's Avatar
Tufel
And another
Old Jun 9, 2020 | 11:24 AM
t020673's Avatar
t020673
6th Gear
I realize your review is over 5 years old, but I wanted to know if you had any other trouble with your Sumax brackets. I'm looking to put some hard bags on my 2011 FXDB (Street Bob). Did you have plenty of clearance between your exhaust and the bags? Was your bike raised/lowered? Anything else I should consider before I buy the Sumax bracket??
ILLADELPHFATBOY
Audio Systems
13
Mar 5, 2016 06:28 PM
bigzig89
Feb 22, 2014 01:47 PM
Catfish57
Mar 14, 2009 08:09 PM
Skyking75
Feb 3, 2009 07:12 PM
Z
Oct 11, 2007 06:37 PM
