Supermeg in the house!
As for the fit, I had the same experience, took some jiggling around to get it all right. The heat shield on the lower pipe does not meet with the collector shield perfectly, maybe off an eighth of an inch, just a titch.
So the 8-disk logic would say that 12 disks w/open end cap would match the 20 closed I'm currently at? I don't want to screw up the sweet dyno-tune I currently have. I may want to try it out. At least I could always go back easy enough.
I still have a couple more important projects first though. My Ohlins rears just arrived - so they go on first, then I need to move the rear sigs to the plate holder, cause I need saddlebags BAD...
I will try loosening everything up and wiggling again to see what happens.
If you want to get rid of that open end cap let me know.
I'm pretty sure that I'll be going back to the open cap some time soon, but you can find them on eBay pretty cheaply. For $25 it's worth experimenting.
Good luck!
A pansy... lawl
I'm sure I'll pick one up and give it a try.
I have a '14 FXDB with SE A/C and a supertrapp supermeg. It's not been dyno tuned. I have the "flash" dealer download and it runs quite good with 20 disks. (a bit of decel pops)
Torque is insane. I've raced buddies with 103's and 96's with similar mods and I am faster off the line and from a roll too. They both have short exhaust and obviously they lack the torque i have.
I'm a bit disapointed on the dyno though, only 6hp gain? I thought the gains after a dyno tune would be more than that. However, 77hp and 95 TQ is very good with basic mods. That's 89 HP and 109TQ at the motor (15% loss).
The sound is a question of taste, but like it's been mentionned in this thread, it does sound like a big block motorcross, and me coming from a motocross background, i don't really dislike this!
I will eventually get mine on the dyno, but for now it runs great and will do the suspension before.
I'm real happy with the drivability. Power is right there from 2000 on up.
I just installed a Superbrace and Ohlins S36E rears so I'm looking forward to getting out there. Being insane, I'm waiting the specified 24hours for the loctite to set on the brace and shocks. Hopefully tomorrow there will be a break in this miserable f'n weather and I can get out and see how the suspension feels... Maybe.
Good choice on the ohlins. Got any pics? What lenght shocks did you go with? Pics?
Stock length 12 1/8" - didn't want to change the jiffy stand again (had to on my old FXD when I went with a 13 3/8" shock. Lean was way too much with the stock stand.
