bike won't start after warming up
Old Jul 3, 2015 | 07:38 PM
narrowglide's Avatar
narrowglide
4th Gear
Default bike won't start after warming up
Replaced the coil in my 99 but still having the problem. I just ran it for close to 300 miles to a run in b.c.. no speeding (well,,, sort of not), anyways got here and went to grab some suds and it just turned over but didn't catch. I had to engage the choke just to keep it running. Think that's the filter or something else. Appreciate any and all suggestions.
Old Jul 4, 2015 | 08:45 PM
cggorman's Avatar
cggorman
swofford has FI, but it sounds like you have a carb. I assume you always pull the choke for a cold start? I would suspect either an intake air leak or clogged/mistuned idle circuit in the carb.
Old Jul 4, 2015 | 11:20 PM
narrowglide
4th Gear
Default choke pull on cold start
l got a s&s super E (of course) and maybe something got f@#$ up on my 23 mile detour down a gravel road . That being said what should be tweaked for the 478 mile trek back to the grind
Old Jul 5, 2015 | 12:54 AM
MRFREEZE57's Avatar
MRFREEZE57
start as another suggested, check for spark first when it will not start, another trick is to remove spark plugs, pour about a 1/4 teaspoon fresh gasoline direct in to each cylinder, replace the plugs and crank, if it pops a couple times, you will know it is fuel problem, as sometimes a plug will fire in open air, but not under compression. this will rule that out.
Master Dee
Mar 8, 2019 06:57 AM
1911NT
Jul 9, 2016 04:30 PM
Woodys03
Oct 14, 2015 08:09 PM
cdavidj
Sep 1, 2015 11:06 AM
blackcrowe
Jun 11, 2008 02:34 PM
