200mm tire tube?
Old Jul 11, 2015 | 12:09 AM
gartec81's Avatar
gartec81
Default 200mm tire tube?
So I found a hoop 18x5.5 to lace to my stock rear street bob hub
Question is. Largest tube I find says its for a 180x18 tire
Anyone have a link to what tube I would run if I went with a 200x18 rear spoke rim?
Trying to go the cheap route so I'm looking to lace a hoop instead of buying a whole new rim
Old Jul 11, 2015 | 12:38 AM
cggorman's Avatar
cggorman
I'm not turning up anything either. Might be better to seal the rim.
Where did you get your rim? I'm in the market for a set of big hoops, too
Old Jul 11, 2015 | 12:53 AM
gartec81's Avatar
gartec81
https://www.denniskirk.com/551085.sku
Old Sep 5, 2015 | 07:05 AM
bammer's Avatar
bammer
6th Gear
I am getting HD wheels to make a 18x5.5 for me to run a 200. Any info on the tubes yet I have been searching but have found nothing
Old Sep 5, 2015 | 09:25 AM
stilup's Avatar
stilup
It's best to run a slightly narrower tube in your ties to keep the tube from folding during inflation. That tube should be just right.
I run a radial in the rear and use a radial tube that is very thick in the center to protect again spokes.
Old Sep 5, 2015 | 09:58 AM
bammer's Avatar
bammer
6th Gear
I was trying to find which would be good for a 200 tire I have seen some that are 180 would that work in a 200
Old Sep 5, 2015 | 08:21 PM
jmeiers's Avatar
jmeiers
I run no tubes in either the front or rear tire. 18x5.5 with Metzeler 200/50/18.
Old Sep 5, 2015 | 08:53 PM
slyedog's Avatar
slyedog
My invoice from Hogpro shows the tube as a 180-200. My rear is a 18x5.5 with a 180/55/zr18. Make sure you get a new rim strip as well.
Old Sep 5, 2015 | 09:49 PM
Tat2u's Avatar
Tat2u
my 200 is tubeless, the rim uses the rubber rim strip seal, done 30,000 kms on different tyres and no leaks ever
Sean Maloney
Jun 14, 2017 10:59 PM
ekoehler4567
Wheels/Tires
Jun 7, 2017 03:35 PM
HarleyDynaWide
Jan 4, 2015 03:45 PM
xjayx
Jun 22, 2011 08:44 AM
LX HEMI
Dec 31, 2009 08:09 PM
