Bandit clutch timing
Old Aug 5, 2015 | 08:57 AM
  #31
monster715's Avatar
monster715
So the timing mark is 2 bores counter clockwise from the bandit writing. If all the clutches are the same then it looks like I got lucky cuz in my picture the hub also has the timing mark 2 bores counter clockwise from the bandit writing. Thanks pilot!
Old Aug 5, 2015 | 09:30 AM
  #32
HD Pilot's Avatar
HD Pilot
If your #1 pic is at the same orientation as the #3 pic, I would say you are 180 degrees out....
Old Aug 5, 2015 | 09:59 AM
  #33
monster715's Avatar
monster715
No those pictures were taken at different times. Pic #3 was taken when I first put the clutch on and I had realized that the bolts weren't centered in the bores so I had to rotate it a few times until they lined up. If all sportsmans are the same then the timing mark is 2 bores counter clockwise of the bandit writing which if you look at pic #1 then I'm good since the writing on both the hub and pressure plate were lined up and my timing mark on the hub is 2 bores counter of the bandit writing. Obviously next time I have it apart I'll double check but I'm pretty sure it's where it needs to be
Old Aug 5, 2015 | 10:03 AM
  #34
HD Pilot's Avatar
HD Pilot
Good deal!
hillcountryflt
Shovelhead
Aug 1, 2011 08:28 AM
RidemyEVO
EVO
14
Feb 15, 2011 01:30 PM
73novaguy
EVO
Jan 16, 2011 01:21 PM
Sapper-0503
May 10, 2010 11:41 AM
daryl71bus
May 7, 2006 09:39 PM
